Background: I would like to have a simple method of generating attributes using R.
The process below generates an attribute c=a+b, in two ways:
- using the Generate Attributes operator
- using the Execute Script (R) operator, with script "data$c <- data$a + data$b"
The problem is that the latter method messes with any missing values in other attributes, as you can see by comparing attribute z in the two outputs from the process. Why does this happen?
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="654" width="1015">
<operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="179" y="30">
<list key="attribute_values">
<parameter key="a" value="1"/>
<parameter key="b" value="2"/>
</list>
<operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="179" y="120">
<parameter key="z" value=""hi""/>
</list>
<operator activated="true" class="union" compatibility="5.2.008" expanded="true" height="76" name="Union" width="90" x="380" y="30"/>
<operator activated="true" class="generate_attributes" compatibility="5.2.008" expanded="true" height="76" name="Generate Attributes" width="90" x="648" y="30">
<parameter key="c" value="a+b"/>
</list>
<operator activated="true" class="r:execute_script_r" compatibility="5.2.000" expanded="true" height="76" name="gen attribute c" width="90" x="648" y="120">
<parameter key="script" value="data$c <- data$a + data$b"/>
<enumeration key="inputs">
<parameter key="name_of_variable" value="data"/>
</enumeration>
<list key="results">
<parameter key="data" value="Data Table"/>
</list>
<connect from_op="Generate Data by User Specification" from_port="output" to_op="Union" to_port="example set 1"/>
<connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Union" to_port="example set 2"/>
<connect from_op="Union" from_port="union" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
<connect from_op="Generate Attributes" from_port="original" to_op="gen attribute c" to_port="input 1"/>
<connect from_op="gen attribute c" from_port="output 1" to_port="result 2"/>
<portSpacing port="sink_result 2" spacing="72"/>
<portSpacing port="sink_result 3" spacing="180"/>
</process>
</process>
