Hi ,
I am using a cross validation and I want to extract those examples which are misclassified , how may I do it in rapidminer ?
Thanks ,
Arian
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="738" width="1907">
<operator activated="true" class="read_csv" compatibility="5.2.008" expanded="true" height="60" name="Read CSV" width="90" x="45" y="120">
<parameter key="csv_file" value="/home/arian/RM/result/dataSet_Nominal_10PercentRandomSample"/>
<parameter key="column_separators" value=","/>
<parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
<list key="annotations"/>
<list key="data_set_meta_data_information"/>
<operator activated="true" class="select_attributes" compatibility="5.2.008" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="120">
<parameter key="attribute" value="admit"/>
<parameter key="attributes" value="|admit"/>
<operator activated="true" class="date_to_numerical" compatibility="5.2.008" expanded="true" height="76" name="Date to Numerical" width="90" x="313" y="120">
<parameter key="attribute_name" value="discharge"/>
<parameter key="time_unit" value="year"/>
<operator activated="true" class="numerical_to_polynominal" compatibility="5.2.008" expanded="true" height="76" name="Numerical to Polynominal" width="90" x="447" y="120">
<parameter key="attribute" value="discharge"/>
<operator activated="true" class="set_role" compatibility="5.2.008" expanded="true" height="76" name="Set Role" width="90" x="581" y="120">
<parameter key="name" value="event"/>
<operator activated="true" class="select_attributes" compatibility="5.2.008" expanded="true" height="76" name="Nominal_Gini_top18" width="90" x="715" y="120">
<parameter key="attribute" value="age"/>
<parameter key="attributes" value="|age|d_04173|prev_readmissions|num_diags|num_drugs|los|p_14|i_9985|d_08021|d_07891|d_09919|d_47186|d_47146|d_37950|p_12|d_02847|d_47234|day_30_readmits"/>
<operator activated="true" class="x_validation" compatibility="5.2.008" expanded="true" height="130" name="Validation" width="90" x="849" y="120">
<parameter key="number_of_validations" value="3"/>
<parameter key="use_local_random_seed" value="true"/>
<parameter key="parallelize_training" value="true"/>
<parameter key="parallelize_testing" value="true"/>
<process expanded="true" height="629" width="882">
<operator activated="true" class="multiply" compatibility="5.2.008" expanded="true" height="94" name="Multiply" width="90" x="45" y="30"/>
<operator activated="true" class="filter_examples" compatibility="5.2.008" expanded="true" height="76" name="Filter Examples" width="90" x="246" y="30">
<parameter key="condition_class" value="attribute_value_filter"/>
<parameter key="parameter_string" value="event=f"/>
<operator activated="true" class="sample" compatibility="5.2.008" expanded="true" height="76" name="Sample" width="90" x="380" y="30">
<parameter key="sample" value="relative"/>
<parameter key="sample_ratio" value="0.1315"/>
<list key="sample_size_per_class"/>
<list key="sample_ratio_per_class"/>
<list key="sample_probability_per_class"/>
<operator activated="true" class="filter_examples" compatibility="5.2.008" expanded="true" height="76" name="Filter Examples (2)" width="90" x="246" y="345">
<parameter key="parameter_string" value="event=t"/>
<operator activated="true" class="append" compatibility="5.2.008" expanded="true" height="94" name="Append" width="90" x="514" y="255"/>
<operator activated="true" class="naive_bayes" compatibility="5.2.008" expanded="true" height="76" name="Naive Bayes" width="90" x="648" y="255"/>
<connect from_port="training" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Multiply" from_port="output 2" to_op="Filter Examples (2)" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Sample" to_port="example set input"/>
<connect from_op="Sample" from_port="example set output" to_op="Append" to_port="example set 1"/>
<connect from_op="Filter Examples (2)" from_port="example set output" to_op="Append" to_port="example set 2"/>
<connect from_op="Append" from_port="merged set" to_op="Naive Bayes" to_port="training set"/>
<connect from_op="Naive Bayes" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<process expanded="true" height="629" width="431">
<operator activated="true" class="apply_model" compatibility="5.2.008" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
<operator activated="true" class="performance_binominal_classification" compatibility="5.2.008" expanded="true" height="76" name="Performance" width="90" x="246" y="30">
<parameter key="accuracy" value="false"/>
<parameter key="AUC" value="true"/>
<parameter key="f_measure" value="true"/>
<parameter key="false_positive" value="true"/>
<parameter key="false_negative" value="true"/>
<parameter key="true_positive" value="true"/>
<parameter key="true_negative" value="true"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
<portSpacing port="sink_averagable 3" spacing="0"/>
</process>
<connect from_op="Read CSV" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Date to Numerical" to_port="example set input"/>
<connect from_op="Date to Numerical" from_port="example set output" to_op="Numerical to Polynominal" to_port="example set input"/>
<connect from_op="Numerical to Polynominal" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Nominal_Gini_top18" to_port="example set input"/>
<connect from_op="Nominal_Gini_top18" from_port="example set output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 1"/>
</process>
</process>
