Maybe I am over looking something, or maybe my brain is not fully engaged with the install process, but when I get to section 1.3.1 "Extracting the RapidAnalytics Archive". when I have extracted my JBoss Bundle....then Where do I put it?
I am on a windows system, and my install directory is c:\rapidanalytics. It would appear that that is where I put the files, but The installer already created those.
I am installing to MS SQL, and got a good connection test in the installer. Everything appears good, except that I can not open in my browser, and I have not been able to complete this step.
I get teh following errors when executing run.bat
Starting RapidAnalytics Server [2012-11-26 13:50:35]
Calling C:\rapidanalytics\bin\run.conf.bat
JBoss Bootstrap Environment
JBOSS_HOME: C:\\rapidanalytics\\
JAVA: C:\\Program Files\\Java\\jdk1.7.0_03\bin\java
JAVA_OPTS: -Dprogram.name=run.bat -Xms128M -Xmx1024M -XX:MaxPermSize=256M -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Dorg.jboss.resolver.warning=true -server
CLASSPATH: C:\\Program Files\\Java\\jdk1.7.0_03\lib\tools.jar;C:\\rapidanalytics\\\bin\run.jar
13:50:41,144 INFO [AbstractJBossASServerBase] Server Configuration:
JBOSS_HOME URL: file:/C:/rapidanalytics/
Bootstrap: $JBOSS_HOME\server/default/conf/bootstrap.xml
Common Base: $JBOSS_HOME\common/
Common Library: $JBOSS_HOME\common/lib/
Server Name: default
Server Base: $JBOSS_HOME\server/
Server Library: $JBOSS_HOME\server/default/lib/
Server Config: $JBOSS_HOME\server/default/conf/
Server Home: $JBOSS_HOME\server/default/
Server Data: $JBOSS_HOME\server/default/data
Server Log: $JBOSS_HOME\server/default/log/
Server Temp: $JBOSS_HOME\server/default/tmp
13:50:41,160 INFO [AbstractServer] Starting: JBossAS [6.0.0.Final "Neo"]
13:50:47,331 INFO [ServerInfo] Java version: 1.7.0_03,Oracle Corporation
13:50:47,331 INFO [ServerInfo] Java Runtime: Java(TM) SE Runtime Environment (build 1.7.0_03-b05)
13:50:47,331 INFO [ServerInfo] Java VM: Java HotSpot(TM) Server VM 22.1-b02,Oracle Corporation
13:50:47,331 INFO [ServerInfo] OS-System: Windows XP 5.1,x86
13:50:47,331 INFO [ServerInfo] VM arguments: -Dprogram.name=run.bat -Xms128M -Xmx1024M -XX:MaxPermSize=256M -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Dorg.jboss.resolver.warning=true -Djava.endorsed.dirs=C:\\rapidanalytics\\\lib\endorsed
13:50:47,394 INFO [JMXKernel] Legacy JMX core initialized
13:51:07,035 INFO [AbstractServerConfig] JBoss Web Services - Stack CXF Server 3.4.1.GA
13:51:08,941 ERROR [STDERR] SLF4J: Class path contains multiple SLF4J bindings.
13:51:08,941 ERROR [STDERR] SLF4J: Found binding in [vfs:/C:/rapidanalytics/common/lib/slf4j-jboss-logmanager.jar/org/slf4j/impl/StaticLoggerBinder.class]
13:51:08,941 ERROR [STDERR] SLF4J: Found binding in [vfs:/C:/rapidanalytics/server/default/lib/slf4j-simple-1.6.4.jar/org/slf4j/impl/StaticLoggerBinder.class]
13:51:08,941 ERROR [STDERR] SLF4J: See
http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
13:51:09,472 ERROR [STDERR] 516 [JBossWS-CXF-DefaultBus-Init] INFO org.jboss.wsf.stack.cxf.client.configuration.JBossWSBusApplicationContext - Refreshing org.jboss.wsf.stack.cxf.client.configuration.JBossWSBusApplicationContext@1680781: startup date [Mon Nov 26 13:51:08 CST 2012]; root of context hierarchy
13:51:09,535 INFO [JSFImplManagementDeployer] Initialized 4 JSF configurations: [Mojarra-2.1.7, Mojarra-1.2, MyFaces-2.0, Mojarra-2.0]
13:51:10,019 ERROR [STDERR] 1063 [JBossWS-CXF-DefaultBus-Init] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1ebb1ef: defining beans []; root of factory hierarchy
13:51:10,035 ERROR [STDERR] 1079 [JBossWS-CXF-DefaultBus-Init] INFO org.jboss.wsf.stack.cxf.client.configuration.JBossWSBusApplicationContext - Refreshing org.jboss.wsf.stack.cxf.client.configuration.JBossWSBusApplicationContext@1680781: startup date [Mon Nov 26 13:51:10 CST 2012]; root of context hierarchy
