[SOLVED] Information Extraction Plugin TreeCreatorAndPreprocessor Problem
dobiHUN
dobiHUN New Altair Community Member
I'd like to use Information Extraction Plugin 1.0.2 for Rapidminer, but i have a problem.
I'd like to create the parse tree with TreeCreatorAndPreprocessor Operator and visualize it with ParseTreeVisualizer Operator.
I'm using only one sentence stored in an text-type-attribute (the attribute name is textattribute in my workflow).
I have two workflows:
1; if the tree is already given by its string representation like Stanford Parser: (ROOT (S (NP (NNP Felix)) (VP (VBD went) (PP (TO to) (NP (NNP New) (NNP York))) (S (VP (TO to) (VP (VB visit) (NP (NP (DT the) (NN statue)) (PP (IN of ) (NP (NN liberty)))))))) (. .)))
2; if a sentence (Felix went to New York to visit the statue of liberty.) is contained in the attribute selected by the parameter valueAttribute
The TreeCreatorAndPreprocessor Operator generates an empty (?) structID, and the object-attribute which is used to store the parse tree can not be created, and the parse-tree Visualizer prints nothing.
In the 1; case, the "needParsing option" need not to be selected, because my sentence are already parsed.
In the 2; case, the "needParsing option" need to be selected, because i have only simple sentence without parsing , but where can i download the MODELFILE if i want to create the parse tree? I found the Stanford Parser modelfile: englisgPCFG.ser file (i attached it in the llink), is this correct for the modelfile? If it is not correct modelfile, where can i download?
Could you help me with your answer or correct my workflow that it can create and visualize the parse tree or send me a sample process where the TreeCreatorAndPreprocessor Operator works?
I tried to use several verison of Rapidminer (5.0, 5.1, 5.2 and the newest one too).
I attached my two worflow rapidminer files with my two input text files, downloaded modelfile, and the plugin.
http://dobi.web.elte.hu/rapidminer_workflow.rar
Thank you for your help in advance,
Best regards
Hadobás András
first workflow xml file:
<process version="5.2.006">
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
 <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process">
   <process expanded="true" height="641" width="567">
     <operator activated="true" class="text:read_document" compatibility="5.2.003" expanded="true" height="60" name="Read Document" width="90" x="45" y="30">
       <parameter key="file" value="D:\rapidminer_workflow\first workflow StructueredTreeString.txt"/>
     <operator activated="true" class="text:documents_to_data" compatibility="5.2.003" expanded="true" height="76" name="Documents to Data" width="90" x="179" y="30">
       <parameter key="text_attribute" value="textattribute"/>
     <operator activated="false" class="informationExtraction:sentence_tokenizer" compatibility="1.0.000" expanded="true" height="76" name="SentenceTokenizer" width="90" x="179" y="120">
       <parameter key="attribute" value="textattribute"/>
       <parameter key="new token-name" value="sentenceattribute"/>
     <operator activated="false" class="text_to_nominal" compatibility="5.2.006" expanded="true" height="76" name="Text to Nominal" width="90" x="313" y="120">
     <operator activated="false" class="informationExtraction:parsetree_visualizer" compatibility="1.0.000" expanded="true" height="76" name="ParseTreeVisualizer" width="90" x="447" y="210"/>
     <operator activated="false" class="informationExtraction:html_tree_preprocessing" compatibility="1.0.000" expanded="true" height="60" name="HTMLTreePreprocessing" width="90" x="447" y="120">
       <parameter key="valueAttribute" value="textattribute"/>
       <parameter key="needParsing" value="true"/>
     <operator activated="true" class="informationExtraction:parsetree_preprocessing_new" compatibility="1.0.000" expanded="true" height="60" name="TreeCreatorAndPreprocessor" width="90" x="447" y="30">
       <parameter key="modelfile" value="D:\rapidminer_workflow\modelfile englishPCFG.ser"/>
       <list key="poslist"/>
     <connect from_op="Read Document" from_port="output" to_op="Documents to Data" to_port="documents 1"/>
     <connect from_op="Documents to Data" from_port="example set" to_op="TreeCreatorAndPreprocessor" to_port="example set input"/>
     <connect from_op="TreeCreatorAndPreprocessor" from_port="example set output" to_port="result 1"/>
   </process>
</process>
second workflow:
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
       <parameter key="file" value="D:\rapidminer_workflow\second workflow UnStructuredString.txt"/>
   </process>
</process>
Welcome!
  • lashkari_ma
    lashkari_ma New Altair Community Member
    Hi
    How did you solved your problem? I have also this problem
  • dobiHUN
    mahdilashkari wrote:
    Hi
    This is Felix Jungermann answer:
    Dear Andras,
    the first rmp-file is almost correct: the 'bracketed' String is converted into a special attribute type which is contained in the structID-Attribute. That attribute only is used by certain tree-structure-operators. To visualize the tree, you should use the Visualizer like I did in the attached rmp-file.
    For the second experiment, you should use the attached model. Unfortunately, the used Stanford parser is not up to date, which means that only older models can be used.
    Additionally, I do not work at the university any more so I am not really able to keep the plugin up to date.
    But I will try to help you if you have further questions.
    Best,
    Felix
    Yout can download
    the old one: http://dobi.web.elte.hu/rapidminer_workflow.rar
    the new one: http://dobi.web.elte.hu/Andras.rar
    Use the modelfile, which is in the Andras.rar, and this will work.
    Bye,
    Andras
  • chaitanya_live
    chaitanya_live New Altair Community Member
    I've tried a lot of versions of the Stanford parser to see if the older versions can produce models that can be used in this same issue with Tree Creator and Pre Processor with text document. But the result is the same. ID  & structID attributes with all missing "?" values.
    Please advice the solution.
Welcome!
Welcome!
