<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="464" width="792"> <operator activated="true" class="generate_data" compatibility="5.3.000" expanded="true" height="60" name="Generate Data" width="90" x="45" y="120"/> <operator activated="true" class="generate_id" compatibility="5.3.000" expanded="true" height="76" name="Generate ID" width="90" x="179" y="120"/> <operator activated="true" class="series:windowing" compatibility="5.2.001" expanded="true" height="76" name="Windowing" width="90" x="313" y="120"> <parameter key="window_size" value="3"/> </operator> <operator activated="true" class="remember" compatibility="5.3.000" expanded="true" height="60" name="Remember" width="90" x="447" y="30"> <parameter key="name" value="data"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator activated="true" class="loop_attributes" compatibility="5.3.000" expanded="true" height="76" name="Loop Attributes" width="90" x="581" y="120"> <process expanded="true" height="464" width="815"> <operator activated="true" class="recall" compatibility="5.3.000" expanded="true" height="60" name="Recall" width="90" x="45" y="30"> <parameter key="name" value="data"/> <parameter key="io_object" value="ExampleSet"/> <parameter key="remove_from_store" value="false"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.000" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="%{loop_attribute}-.*"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.000" expanded="true" height="76" name="Select Attributes (2)" width="90" x="313" y="165"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="%{loop_attribute}-.*"/> <parameter key="invert_selection" value="true"/> </operator> <operator activated="true" class="subprocess" compatibility="5.3.000" expanded="true" height="76" name="Do Something" width="90" x="313" y="30"> <process expanded="true" height="464" width="792"> <operator activated="false" class="select_attributes" compatibility="5.3.000" expanded="true" height="76" name="Select Attributes (3)" width="90" x="179" y="75"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="att2-1"/> <parameter key="invert_selection" value="true"/> </operator> <connect from_port="in 1" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="join" compatibility="5.3.000" expanded="true" height="76" name="Join" width="90" x="447" y="30"> <list key="key_attributes"/> </operator> <operator activated="true" class="remember" compatibility="5.3.000" expanded="true" height="60" name="Remember (2)" width="90" x="581" y="30"> <parameter key="name" value="data"/> <parameter key="io_object" value="ExampleSet"/> </operator> <connect from_op="Recall" from_port="result" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Do Something" to_port="in 1"/> <connect from_op="Select Attributes" from_port="original" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Do Something" from_port="out 1" to_op="Join" to_port="left"/> <connect from_op="Join" from_port="join" to_op="Remember (2)" to_port="store"/> <connect from_op="Remember (2)" from_port="stored" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Windowing" to_port="example set input"/> <connect from_op="Windowing" from_port="example set output" to_op="Remember" to_port="store"/> <connect from_op="Windowing" from_port="original" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="557" width="902"> <operator activated="true" class="generate_data" compatibility="5.2.008" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_examples" value="10"/> <parameter key="number_of_attributes" value="3"/> <parameter key="attributes_lower_bound" value="0.0"/> </operator> <operator activated="true" class="loop_attributes" compatibility="5.2.008" expanded="true" height="60" name="Loop Attributes" width="90" x="179" y="30"> <process expanded="true" height="540" width="622"> <operator activated="true" class="provide_macro_as_log_value" compatibility="5.2.008" expanded="true" height="76" name="Provide Macro as Log Value" width="90" x="45" y="30"> <parameter key="macro_name" value="loop_attribute"/> </operator> <operator activated="true" class="log" compatibility="5.2.008" expanded="true" height="76" name="Log" width="90" x="179" y="30"> <list key="log"> <parameter key="cn" value="operator.Provide Macro as Log Value.value.macro_value"/> </list> </operator> <connect from_port="example set" to_op="Provide Macro as Log Value" to_port="through 1"/> <connect from_op="Provide Macro as Log Value" from_port="through 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <operator activated="true" class="extract_macro" compatibility="5.2.008" expanded="true" height="60" name="Extract Macro (2)" width="90" x="313" y="30"> <parameter key="macro" value="int"/> <parameter key="macro_type" value="number_of_attributes"/> </operator> <operator activated="true" class="series:windowing" compatibility="5.2.000" expanded="true" height="76" name="Windowing" width="90" x="447" y="30"> <parameter key="horizon" value="1"/> <parameter key="window_size" value="2"/> <parameter key="create_label" value="true"/> <parameter key="label_attribute" value="att1"/> </operator> <operator activated="true" class="log_to_data" compatibility="5.2.008" expanded="true" height="94" name="Log to Data" width="90" x="581" y="30"> <parameter key="log_name" value="Log"/> </operator> <operator activated="true" class="loop" compatibility="5.2.008" expanded="true" height="94" name="Loop" width="90" x="715" y="30"> <parameter key="set_iteration_macro" value="true"/> <parameter key="iterations" value="%{int}"/> <process expanded="true" height="557" width="622"> <operator activated="true" class="extract_macro" compatibility="5.2.008" expanded="true" height="60" name="Extract Macro" width="90" x="112" y="30"> <parameter key="macro" value="att_name"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="cn"/> <parameter key="example_index" value="%{iteration}"/> </operator> <operator activated="true" class="work_on_subset" compatibility="5.2.008" expanded="true" height="76" name="Work on Subset" width="90" x="179" y="120"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="%{att_name}.*"/> <parameter key="keep_subset_only" value="true"/> <process expanded="true" height="557" width="622"> <operator activated="true" class="select_attributes" compatibility="5.2.008" expanded="true" height="76" name="Select Attributes" width="90" x="112" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="%{att_name}-0"/> </operator> <operator activated="false" class="weight_by_correlation" compatibility="5.2.008" expanded="true" height="76" name="Weight by Correlation" width="90" x="112" y="165"> <parameter key="normalize_weights" value="false"/> </operator> <operator activated="false" class="select_by_weights" compatibility="5.2.008" expanded="true" height="94" name="Select by Weights" width="90" x="246" y="165"> <parameter key="weight_relation" value="top k"/> <parameter key="k" value="3"/> </operator> <connect from_port="exampleSet" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="example set"/> <connect from_op="Weight by Correlation" from_port="weights" to_op="Select by Weights" to_port="weights"/> <connect from_op="Weight by Correlation" from_port="example set" to_op="Select by Weights" to_port="example set input"/> <portSpacing port="source_exampleSet" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> </operator> <connect from_port="input 1" to_op="Extract Macro" to_port="example set"/> <connect from_port="input 2" to_op="Work on Subset" to_port="example set"/> <connect from_op="Work on Subset" from_port="example set" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="source_input 3" spacing="0"/> <portSpacing port="sink_output 1" spacing="90"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_op="Extract Macro (2)" to_port="example set"/> <connect from_op="Extract Macro (2)" from_port="example set" to_op="Windowing" to_port="example set input"/> <connect from_op="Windowing" from_port="example set output" to_op="Log to Data" to_port="through 1"/> <connect from_op="Log to Data" from_port="exampleSet" to_op="Loop" to_port="input 1"/> <connect from_op="Log to Data" from_port="through 1" to_op="Loop" to_port="input 2"/> <connect from_op="Loop" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
