Did you finally receive any content or example of GLM functionality in Rapidminer?
I am looking for the same.
Thanks
A
it's in for quite a while now. just search for glm in the operators.
Best,
Martin
Yes, I read through the operators documentations. I would like more info on how to specify beta constraints.
My model has around 30 input variables and I want to constrain the coefficients of few variables as positive (because I know that the relationship is +ve) by specifying a lower bound as 0 and upper bound as +infinity. I am struggling to implement it in the paramters window (screenshots):
- What is the 'category' input right next to attribute name?
- How to input +infinity as upper bound?
screenshot of the documentation
Hi @am_das,
That is a good question. The beta constraint parameter can be setup in your GLM.
In my attached process, I used deals data with customer profile. Input data has a categorical variable "payement method" and suppose I know the coefficients (beta) for that "credit card" category need to be positve, then I set up the constraints for the coefficients of that category.
upper_bounds is (optional): The upper bounds of the beta. Must be greater than or equal to lower_bounds. You need to have real value there.
Hope this helps.
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="8.1.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="8.1.001" expanded="true" height="68" name="Retrieve Deals" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/data/Deals"/> </operator> <operator activated="true" class="h2o:generalized_linear_model" compatibility="7.2.000" expanded="true" height="124" name="Generalized Linear Model" width="90" x="179" y="34"> <parameter key="specify_beta_constraints" value="true"/> <list key="beta_constraints"> <parameter key="Payment Method.credit card" value="0\.01.5\.0.0\.0.0\.0"/> </list> <list key="expert_parameters"/> </operator> <operator activated="true" class="retrieve" compatibility="8.1.001" expanded="true" height="68" name="Retrieve Deals-Testset" width="90" x="179" y="238"> <parameter key="repository_entry" value="//Samples/data/Deals-Testset"/> </operator> <operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="82" name="Apply Model" width="90" x="380" y="34"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_classification" compatibility="8.1.001" expanded="true" height="82" name="Performance" width="90" x="514" y="85"> <list key="class_weights"/> </operator> <connect from_op="Retrieve Deals" from_port="output" to_op="Generalized Linear Model" to_port="training set"/> <connect from_op="Generalized Linear Model" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Retrieve Deals-Testset" from_port="output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Apply Model" from_port="model" to_port="result 2"/> <connect from_op="Performance" from_port="performance" to_port="result 1"/> <connect from_op="Performance" from_port="example set" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
YY
