Hi, I ran SVM with kernel type set to polynomial on RM and it used to work fine. But after more experiments It started to giving errors Cannot deliver AttributeWeights with parameter "kernel_type" set to "polynomial". May I know what I did wrong? After a few weeks, I reinstall RM and now Even the field changes , It used to be kernel shift =1, max evaluations= 500 , generations without improvement =10, population size =10, inertia weight =1.0 and global best weight =1.0 but now it changed to convergence epsilon= 0.001, max iterations = 100000, L pos = 1.0 etc. I am almost certain that I didn't use SVM (PSO)
Thanks in advance
