correlacion entre variables de temperaturas
Good evening, I'm starting to use this excellent tool me, but I had trouble with it. acontinuación explain:
in the example is required to determine the correlation between the temperatures given by sensors (43) located in a datacenter racks, namely the correlation between temperature variables which tell me if a temperature influences the other and that percentage, as a method of predicting the behavior of air conditioning and how it affects the data center equipment.
I have a database with the following fields: date (date; attribute), time (time; attribute), temperature (real label), id_sensor (integer, id), x, y, z location of the sensor (polynomial; actual ), area (integer; attribute), No. rack (integer, attribute). Exported the database to RapidMiner, the process is correct, but I can not know how to make the correlation between the temperature variables.
I appreciate the help they can provideme,
