<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="494" width="1016"> <operator activated="true" class="generate_massive_data" compatibility="5.2.008" expanded="true" height="60" name="Generate Massive Data" width="90" x="112" y="75"> <parameter key="number_examples" value="1000"/> <parameter key="number_attributes" value="100"/> <parameter key="sparse_fraction" value="0.95"/> </operator> <operator activated="true" class="nominal_to_binominal" compatibility="5.2.008" expanded="true" height="94" name="Nominal to Binominal" width="90" x="313" y="75"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> </operator> <operator activated="true" class="weka:W-ReliefFAttributeEval" compatibility="5.1.001" expanded="true" height="76" name="W-ReliefFAttributeEval" width="90" x="447" y="75"> <parameter key="sort_direction" value="descending"/> </operator> <operator activated="true" class="select_by_weights" compatibility="5.2.008" expanded="true" height="94" name="Select by Weights" width="90" x="648" y="75"> <parameter key="weight_relation" value="top k"/> <parameter key="weight" value="0.0"/> <parameter key="k" value="25"/> </operator> <operator activated="true" class="x_validation" compatibility="5.2.008" expanded="true" height="112" name="Validation" width="90" x="782" y="75"> <process expanded="true" height="649" width="522"> <operator activated="true" class="naive_bayes" compatibility="5.2.008" expanded="true" height="76" name="Naive Bayes" width="90" x="216" y="30"/> <connect from_port="training" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="649" width="522"> <operator activated="true" class="apply_model" compatibility="5.2.008" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="5.2.008" expanded="true" height="76" name="Performance" width="90" x="283" y="30"> <parameter key="accuracy" value="false"/> <parameter key="AUC" value="true"/> <parameter key="f_measure" value="true"/> <parameter key="false_positive" value="true"/> <parameter key="false_negative" value="true"/> <parameter key="true_positive" value="true"/> <parameter key="true_negative" value="true"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="write_as_text" compatibility="5.2.008" expanded="true" height="76" name="Write as Text" width="90" x="916" y="75"> <parameter key="result_file" value="/home/arian/resultttt.res"/> </operator> <connect from_op="Generate Massive Data" from_port="output" to_op="Nominal to Binominal" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="example set output" to_op="W-ReliefFAttributeEval" to_port="example set"/> <connect from_op="W-ReliefFAttributeEval" from_port="weights" to_op="Select by Weights" to_port="weights"/> <connect from_op="W-ReliefFAttributeEval" from_port="example set" to_op="Select by Weights" to_port="example set input"/> <connect from_op="Select by Weights" from_port="example set output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_op="Write as Text" to_port="input 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="631" width="949"> <operator activated="true" class="generate_massive_data" compatibility="5.2.008" expanded="true" height="60" name="Generate Massive Data" width="90" x="45" y="75"> <parameter key="number_examples" value="1000"/> <parameter key="number_attributes" value="100"/> <parameter key="sparse_fraction" value="0.95"/> </operator> <operator activated="true" class="nominal_to_binominal" compatibility="5.2.008" expanded="true" height="94" name="Nominal to Binominal" width="90" x="179" y="75"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="weka:W-ReliefFAttributeEval" compatibility="5.1.001" expanded="true" height="76" name="W-ReliefFAttributeEval (3)" width="90" x="313" y="75"> <parameter key="sort_direction" value="descending"/> <parameter key="K" value="21.0"/> </operator> <connect from_op="Generate Massive Data" from_port="output" to_op="Nominal to Binominal" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="example set output" to_op="W-ReliefFAttributeEval (3)" to_port="example set"/> <connect from_op="W-ReliefFAttributeEval (3)" from_port="weights" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="631" width="949"> <operator activated="true" class="generate_massive_data" compatibility="5.2.008" expanded="true" height="60" name="Generate Massive Data" width="90" x="45" y="75"> <parameter key="number_examples" value="1000"/> <parameter key="number_attributes" value="100"/> <parameter key="sparse_fraction" value="0.95"/> </operator> <operator activated="true" class="nominal_to_binominal" compatibility="5.2.008" expanded="true" height="94" name="Nominal to Binominal" width="90" x="179" y="75"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="store" compatibility="5.2.008" expanded="true" height="60" name="Store" width="90" x="380" y="75"> <parameter key="repository_entry" value="//RMRepository/testRemoteStorage"/> </operator> <connect from_op="Generate Massive Data" from_port="output" to_op="Nominal to Binominal" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="example set output" to_op="Store" to_port="input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
