if(myAttribute < 0.001, 0, myAttribute)
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <parameter key="logverbosity" value="all"/> <parameter key="logfile" value="H:\SEKS\KnowledgeSources\log.txt"/> <parameter key="resultfile" value="H:\SEKS\KnowledgeSources\result.csv"/> <parameter key="parallelize_main_process" value="true"/> <process expanded="true" height="791" width="815"> <operator activated="false" class="text:process_document_from_file" compatibility="5.2.004" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="30"> <list key="text_directories"> <parameter key="Waste Management" value="H:\SEKS\KnowledgeSources\ICONDA\Waste Management\TXT"/> <parameter key="Climate Control" value="H:\SEKS\KnowledgeSources\ICONDA\Climate Control\TXT"/> <parameter key="Utility & Transportation" value="H:\SEKS\KnowledgeSources\ICONDA\Utility and Transportation\TXT"/> <parameter key="Electric Power & Lighting" value="H:\SEKS\KnowledgeSources\ICONDA\Electric Power and Lighting\TXT"/> <parameter key="Information & Communication" value="H:\SEKS\KnowledgeSources\ICONDA\Information and Communication\TXT"/> </list> <parameter key="content_type" value="pdf"/> <parameter key="prune_method" value="percentual"/> <parameter key="prunde_below_percent" value="2.0"/> <parameter key="prune_above_percent" value="100.0"/> <parameter key="prune_below_rank" value="0.9"/> <parameter key="prune_above_rank" value="0.5"/> <parameter key="parallelize_vector_creation" value="true"/> <process expanded="true" height="663" width="1094"> <operator activated="false" class="text:tokenize" compatibility="5.2.004" expanded="true" height="60" name="Tokenize" width="90" x="112" y="75"/> <operator activated="false" class="text:transform_cases" compatibility="5.2.004" expanded="true" height="60" name="Transform Cases" width="90" x="112" y="210"/> <operator activated="false" class="text:filter_stopwords_english" compatibility="5.2.004" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="122" y="351"/> <operator activated="false" class="text:stem_snowball" compatibility="5.2.004" expanded="true" height="60" name="Stem (Snowball)" width="90" x="112" y="480"/> <operator activated="false" class="text:filter_by_length" compatibility="5.2.004" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="380" y="480"> <parameter key="max_chars" value="50"/> </operator> <operator activated="false" class="text:generate_n_grams_terms" compatibility="5.2.004" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="581" y="345"> <parameter key="max_length" value="3"/> </operator> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Stem (Snowball)" to_port="document"/> <connect from_op="Stem (Snowball)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/> <connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="false" class="data_to_similarity" compatibility="5.2.008" expanded="true" height="76" name="Data to Similarity (2)" width="90" x="246" y="435"> <parameter key="measure_types" value="NumericalMeasures"/> </operator> <operator activated="false" class="data_to_similarity" compatibility="5.2.008" expanded="true" height="76" name="Data to Similarity" width="90" x="246" y="75"> <parameter key="measure_types" value="NumericalMeasures"/> <parameter key="numerical_measure" value="CosineSimilarity"/> </operator> <operator activated="false" class="store" compatibility="5.2.008" expanded="true" height="60" name="Store" width="90" x="441" y="59"> <parameter key="repository_entry" value="ICONDAwl"/> </operator> <operator activated="false" class="item_distribution_performance" compatibility="5.2.008" expanded="true" height="76" name="Performance (4)" width="90" x="581" y="615"/> <operator activated="false" class="cluster_count_performance" compatibility="5.2.008" expanded="true" height="76" name="Performance (3)" width="90" x="581" y="525"/> <operator activated="false" class="map_clustering_on_labels" compatibility="5.2.008" expanded="true" height="76" name="Map Clustering on Labels" width="90" x="581" y="705"/> <operator activated="false" class="cluster_density_performance" compatibility="5.2.008" expanded="true" height="112" name="Performance" width="90" x="581" y="390"/> <operator activated="true" class="retrieve" compatibility="5.2.008" expanded="true" height="60" name="Retrieve" width="90" x="45" y="255"> <parameter key="repository_entry" value="ICONDA/2nd Iteration/wordlist2"/> </operator> <operator activated="true" class="loop_attributes" compatibility="5.2.008" expanded="true" height="60" name="Loop Attributes" width="90" x="246" y="255"> <process expanded="true" height="645" width="1076"> <operator activated="true" class="generate_attributes" compatibility="5.2.008" expanded="true" height="76" name="Generate Attributes" width="90" x="313" y="30"> <list key="function_descriptions"> <parameter key="loop_attribute" value="if(loop_attribute < 0.001, 0, loop_attribute)"/> </list> </operator> <connect from_port="example set" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <operator activated="true" class="k_means" compatibility="5.2.008" expanded="true" height="76" name="Clustering" width="90" x="447" y="255"> <parameter key="k" value="5"/> <parameter key="determine_good_start_values" value="true"/> </operator> <operator activated="true" class="cluster_distance_performance" compatibility="5.2.008" expanded="true" height="94" name="Performance (2)" width="90" x="648" y="255"/> <connect from_op="Retrieve" from_port="output" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_op="Performance (2)" to_port="cluster model"/> <connect from_op="Clustering" from_port="clustered set" to_op="Performance (2)" to_port="example set"/> <connect from_op="Performance (2)" from_port="performance" to_port="result 1"/> <connect from_op="Performance (2)" from_port="example set" to_port="result 2"/> <connect from_op="Performance (2)" from_port="cluster model" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
