<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="386" width="748"> <operator activated="true" class="subprocess" compatibility="5.3.000" expanded="true" height="76" name="Create imbalanced data" width="90" x="45" y="30"> <process expanded="true" height="506" width="821"> <operator activated="true" class="generate_data" compatibility="5.3.000" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_examples" value="1000"/> <parameter key="number_of_attributes" value="1"/> <parameter key="attributes_lower_bound" value="0.0"/> <parameter key="attributes_upper_bound" value="1.0"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.000" expanded="true" height="76" name="Generate Attributes" width="90" x="246" y="30"> <list key="function_descriptions"> <parameter key="label" value="if(att1>0.9,1,0)"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.000" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="246" y="30"> <list key="function_descriptions"> <parameter key="weight" value="if(label==1,10,1)"/> </list> </operator> <operator activated="true" class="set_role" compatibility="5.3.000" expanded="true" height="76" name="Set Role" width="90" x="380" y="30"> <parameter key="name" value="weight"/> <parameter key="target_role" value="weight"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="sample_bootstrapping" compatibility="5.3.000" expanded="true" height="76" name="Sample (Bootstrapping)" width="90" x="514" y="30"> <parameter key="sample" value="absolute"/> <parameter key="sample_size" value="1000"/> </operator> <connect from_op="Create imbalanced data" from_port="out 1" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Sample (Bootstrapping)" to_port="example set input"/> <connect from_op="Sample (Bootstrapping)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
