Marius wrote:No, not yet, and to be honest it does not have high priority for us. There are a number of algorithms that we prefer a lot over the Neural Networks - SVMs for instance deliver comparable results, but are way easier to configure and to optimize and at the same time have a smaller tendency to overfit.However, to change at least the size of a fixed number of hidden Layers, you can create Set Macro operators inside the Loop Parameters operator, iterate the macro values and use the macros to define the sizes of the layers.Best, Marius
I solved the problem same way, too.
Thank you very much.
hello everyone .i need some mor help! to undersatanding this solved problem.....can you share with me some xml or jpg for more describtion...
Have you tried pinging @yasinkaya?
