<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="1475" width="768"> <operator activated="true" class="retrieve" compatibility="5.2.008" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="../../Data/F C Data"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.2.008" expanded="true" height="76" name="Select Attributes" width="90" x="45" y="120"> <parameter key="attribute_filter_type" value="value_type"/> <parameter key="value_type" value="numeric"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="5.2.008" expanded="true" height="94" name="Replace Missing Values" width="90" x="45" y="210"> <list key="columns"/> </operator> <operator activated="true" class="multiply" compatibility="5.2.008" expanded="true" height="94" name="Multiply" width="90" x="45" y="345"/> <operator activated="true" class="weight_by_gini_index" compatibility="5.2.008" expanded="true" height="76" name="Weight by Gini Index" width="90" x="179" y="210"/> <operator activated="true" class="select_by_weights" compatibility="5.2.008" expanded="true" height="94" name="Select by Weights (5)" width="90" x="380" y="210"> <parameter key="weight" value="0.7"/> </operator> <operator activated="true" class="store" compatibility="5.2.008" expanded="true" height="60" name="Store (5)" width="90" x="581" y="210"> <parameter key="repository_entry" value="../../Results/Attribute Weighting/Gini Index"/> </operator> <operator activated="true" class="weight_by_uncertainty" compatibility="5.2.008" expanded="true" height="76" name="Weight by Uncertainty" width="90" x="171" y="342"/> <operator activated="true" class="select_by_weights" compatibility="5.2.008" expanded="true" height="94" name="Select by Weights (7)" width="90" x="380" y="345"> <parameter key="weight" value="0.7"/> </operator> <operator activated="true" class="store" compatibility="5.2.008" expanded="true" height="60" name="Store (6)" width="90" x="581" y="345"> <parameter key="repository_entry" value="../../Results/Attribute Weighting/Uncertainty"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Weight by Gini Index" to_port="example set"/> <connect from_op="Multiply" from_port="output 2" to_op="Weight by Uncertainty" to_port="example set"/> <connect from_op="Weight by Gini Index" from_port="weights" to_op="Select by Weights (5)" to_port="weights"/> <connect from_op="Weight by Gini Index" from_port="example set" to_op="Select by Weights (5)" to_port="example set input"/> <connect from_op="Select by Weights (5)" from_port="example set output" to_op="Store (5)" to_port="input"/> <connect from_op="Store (5)" from_port="through" to_port="result 1"/> <connect from_op="Weight by Uncertainty" from_port="weights" to_op="Select by Weights (7)" to_port="weights"/> <connect from_op="Weight by Uncertainty" from_port="example set" to_op="Select by Weights (7)" to_port="example set input"/> <connect from_op="Select by Weights (7)" from_port="example set output" to_op="Store (6)" to_port="input"/> <connect from_op="Store (6)" from_port="through" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="468"/> <portSpacing port="sink_result 2" spacing="162"/> <portSpacing port="sink_result 3" spacing="126"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="353" width="701"> <operator activated="true" class="retrieve" compatibility="5.2.008" expanded="true" height="60" name="gini index" width="90" x="45" y="30"> <parameter key="repository_entry" value="../../../Results/Attribute Weighting/Gini Index"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="5.2.008" expanded="true" height="94" name="Replace Missing Values" width="90" x="246" y="30"> <list key="columns"/> </operator> <operator activated="true" class="x_validation" compatibility="5.2.008" expanded="true" height="112" name="Neural Net a" width="90" x="581" y="30"> <parameter key="use_local_random_seed" value="true"/> <process expanded="true" height="506" width="399"> <operator activated="true" class="neural_net" compatibility="5.2.008" expanded="true" height="76" name="Neural Net" width="90" x="154" y="30"> <list key="hidden_layers"/> </operator> <connect from_port="training" to_op="Neural Net" to_port="training set"/> <connect from_op="Neural Net" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="506" width="399"> <operator activated="true" class="apply_model" compatibility="5.2.008" expanded="true" height="76" name="Apply Model (2)" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.2.008" expanded="true" height="76" name="Performance (2)" width="90" x="226" y="30"/> <connect from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="retrieve" compatibility="5.2.008" expanded="true" height="60" name="Uncertainty" width="90" x="45" y="210"> <parameter key="repository_entry" value="../../../Results/Attribute Weighting/Gini Index"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="5.2.008" expanded="true" height="94" name="Replace Missing Values (2)" width="90" x="246" y="210"> <list key="columns"/> </operator> <operator activated="true" class="x_validation" compatibility="5.2.008" expanded="true" height="112" name="Neural Net a (2)" width="90" x="581" y="210"> <parameter key="use_local_random_seed" value="true"/> <process expanded="true"> <operator activated="true" class="neural_net" compatibility="5.2.008" expanded="true" name="Neural Net (2)"> <list key="hidden_layers"/> </operator> <connect from_port="training" to_op="Neural Net (2)" to_port="training set"/> <connect from_op="Neural Net (2)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.2.008" expanded="true" name="Apply Model (3)"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.2.008" expanded="true" name="Performance (3)"/> <connect from_port="model" to_op="Apply Model (3)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (3)" to_port="unlabelled data"/> <connect from_op="Apply Model (3)" from_port="labelled data" to_op="Performance (3)" to_port="labelled data"/> <connect from_op="Performance (3)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_op="gini index" from_port="output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Neural Net a" to_port="training"/> <connect from_op="Neural Net a" from_port="averagable 1" to_port="result 1"/> <connect from_op="Uncertainty" from_port="output" to_op="Replace Missing Values (2)" to_port="example set input"/> <connect from_op="Replace Missing Values (2)" from_port="example set output" to_op="Neural Net a (2)" to_port="training"/> <connect from_op="Neural Net a (2)" from_port="averagable 1" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
