Hi everybody.
in the following, simple, example, where I process a few pages retrieved by a web crawl, I keep seeing the error "The example set must contain at least one text attribute". The "Nominal to Text", which is suggested as a solution this very same problem in other posts, does not remove the error. Interestingly, there seems to be indeed a 'text' attribute in th example set and the error does not seem to affect the execution of the process. What am I missing?
Thanks!
Marco
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="510" width="909">
<operator activated="true" class="web:crawl_web" compatibility="5.2.003" expanded="true" height="60" name="Crawl Web" width="90" x="45" y="345">
<parameter key="url" value="http://www.cnn.com"/>
<list key="crawling_rules"/>
<parameter key="write_pages_into_files" value="false"/>
<parameter key="add_pages_as_attribute" value="true"/>
<parameter key="max_pages" value="10"/>
<parameter key="domain" value="server"/>
<operator activated="true" class="nominal_to_text" compatibility="5.2.008" expanded="true" height="76" name="Nominal to Text" width="90" x="179" y="345"/>
<operator activated="true" class="multiply" compatibility="5.2.008" expanded="true" height="94" name="Multiply" width="90" x="380" y="345"/>
<operator activated="true" class="text:process_document_from_data" compatibility="5.2.004" expanded="true" height="76" name="Process Documents from Data" width="90" x="514" y="255">
<parameter key="vector_creation" value="Term Occurrences"/>
<list key="specify_weights"/>
<operator activated="true" class="text:tokenize" compatibility="5.2.004" expanded="true" height="60" name="Tokenize (2)" width="90" x="246" y="30"/>
<operator activated="true" class="text:generate_n_grams_terms" compatibility="5.2.004" expanded="true" height="60" name="Generate n-Grams (2)" width="90" x="447" y="30"/>
<connect from_port="document" to_op="Tokenize (2)" to_port="document"/>
<connect from_op="Tokenize (2)" from_port="document" to_op="Generate n-Grams (2)" to_port="document"/>
<connect from_op="Generate n-Grams (2)" from_port="document" to_port="document 1"/>
</process>
<connect from_op="Crawl Web" from_port="Example Set" to_op="Nominal to Text" to_port="example set input"/>
<connect from_op="Nominal to Text" from_port="example set output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Multiply" from_port="output 2" to_port="result 2"/>
<connect from_op="Process Documents from Data" from_port="example set" to_port="result 1"/>
</process>
</process>
[ /code]
