<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="116" width="681"> <operator activated="true" class="generate_nominal_data" compatibility="5.3.000" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="30"/> <operator activated="true" breakpoints="after" class="replace" compatibility="5.3.000" expanded="true" height="76" name="Replace (2)" width="90" x="179" y="30"> <parameter key="replace_what" value="value(\d+)"/> <parameter key="replace_by" value="p_$1"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.3.000" expanded="true" height="76" name="Filter Examples" width="90" x="313" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="att1=.*_\d"/> </operator> <operator activated="true" class="replace" compatibility="5.3.000" expanded="true" height="76" name="Replace" width="90" x="447" y="30"> <parameter key="replace_what" value="p_(\d+)"/> <parameter key="replace_by" value="$1"/> </operator> <operator activated="true" class="parse_numbers" compatibility="5.3.000" expanded="true" height="76" name="Parse Numbers" width="90" x="581" y="30"/> <connect from_op="Generate Nominal Data" from_port="output" to_op="Replace (2)" to_port="example set input"/> <connect from_op="Replace (2)" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_op="Parse Numbers" to_port="example set input"/> <connect from_op="Parse Numbers" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
