<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="641" width="1040"> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="112" y="75"> <list key="attribute_values"> <parameter key="a" value="1"/> <parameter key="b" value="2"/> <parameter key="c" value="3"/> <parameter key="d" value="4"/> <parameter key="e" value="5"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="112" y="165"> <list key="attribute_values"> <parameter key="a" value="1"/> <parameter key="b" value="2"/> <parameter key="c" value="3"/> <parameter key="d" value="4"/> <parameter key="e" value="5"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="5.2.008" expanded="true" height="94" name="examplesetA" width="90" x="313" y="120"/> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="a" width="90" x="112" y="300"> <list key="attribute_values"> <parameter key="X" value=""a""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="d" width="90" x="112" y="390"> <list key="attribute_values"> <parameter key="X" value=""d""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="e" width="90" x="112" y="480"> <list key="attribute_values"> <parameter key="X" value=""e""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="5.2.008" expanded="true" height="112" name="examplesetB" width="90" x="313" y="390"/> <operator activated="true" class="set_role" compatibility="5.2.008" expanded="true" height="76" name="Set Role" width="90" x="447" y="345"> <parameter key="name" value="X"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="transpose" compatibility="5.2.008" expanded="true" height="76" name="Transpose" width="90" x="581" y="345"/> <operator activated="true" class="filter_example_range" compatibility="5.2.008" expanded="true" height="76" name="Filter Example Range" width="90" x="715" y="345"> <parameter key="first_example" value="1"/> <parameter key="last_example" value="1"/> </operator> <operator activated="true" class="union" compatibility="5.2.008" expanded="true" height="76" name="Union" width="90" x="849" y="255"/> <connect from_op="Generate Data by User Specification" from_port="output" to_op="examplesetA" to_port="example set 1"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="examplesetA" to_port="example set 2"/> <connect from_op="examplesetA" from_port="merged set" to_op="Union" to_port="example set 1"/> <connect from_op="a" from_port="output" to_op="examplesetB" to_port="example set 1"/> <connect from_op="d" from_port="output" to_op="examplesetB" to_port="example set 2"/> <connect from_op="e" from_port="output" to_op="examplesetB" to_port="example set 3"/> <connect from_op="examplesetB" from_port="merged set" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Transpose" to_port="example set input"/> <connect from_op="Transpose" from_port="example set output" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Union" to_port="example set 2"/> <connect from_op="Union" from_port="union" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="252"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
remove all attributes (with Filter Example Range)
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="641" width="1036"> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="112" y="75"> <list key="attribute_values"> <parameter key="a" value="1"/> <parameter key="b" value="2"/> <parameter key="c" value="3"/> <parameter key="d" value="4"/> <parameter key="e" value="5"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="112" y="165"> <list key="attribute_values"> <parameter key="a" value="1"/> <parameter key="b" value="2"/> <parameter key="c" value="3"/> <parameter key="d" value="4"/> <parameter key="e" value="5"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="5.2.008" expanded="true" height="94" name="examplesetA" width="90" x="313" y="120"/> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="a" width="90" x="112" y="300"> <list key="attribute_values"> <parameter key="X" value=""a""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="d" width="90" x="112" y="390"> <list key="attribute_values"> <parameter key="X" value=""d""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="e" width="90" x="112" y="480"> <list key="attribute_values"> <parameter key="X" value=""e""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="5.2.008" expanded="true" height="112" name="examplesetB" width="90" x="246" y="390"/> <operator activated="true" class="generate_attributes" compatibility="5.2.008" expanded="true" height="76" name="Generate Attributes" width="90" x="380" y="345"> <list key="function_descriptions"> <parameter key="selected" value="1"/> </list> </operator> <operator activated="true" class="set_role" compatibility="5.2.008" expanded="true" height="76" name="Set Role" width="90" x="514" y="345"> <parameter key="name" value="X"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="transpose" compatibility="5.2.008" expanded="true" height="76" name="Transpose" width="90" x="648" y="345"/> <operator activated="true" class="union" compatibility="5.2.008" expanded="true" height="76" name="Union" width="90" x="447" y="165"/> <operator activated="true" class="select_attributes" compatibility="5.2.008" expanded="true" height="76" name="Select Attributes (2)" width="90" x="581" y="165"> <parameter key="attribute_filter_type" value="no_missing_values"/> <parameter key="numeric_condition" value="">=0""/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.2.008" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="715" y="165"> <list key="function_descriptions"> <parameter key="missingId" value="missing(id)!=false"/> </list> </operator> <operator activated="true" class="filter_examples" compatibility="5.2.008" expanded="true" height="76" name="Filter Examples" width="90" x="849" y="165"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="missingId=1"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.2.008" expanded="true" height="76" name="Select Attributes" width="90" x="849" y="345"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value="id"/> <parameter key="attributes" value="|id|missingId"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="examplesetA" to_port="example set 1"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="examplesetA" to_port="example set 2"/> <connect from_op="examplesetA" from_port="merged set" to_op="Union" to_port="example set 1"/> <connect from_op="a" from_port="output" to_op="examplesetB" to_port="example set 1"/> <connect from_op="d" from_port="output" to_op="examplesetB" to_port="example set 2"/> <connect from_op="e" from_port="output" to_op="examplesetB" to_port="example set 3"/> <connect from_op="examplesetB" from_port="merged set" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Transpose" to_port="example set input"/> <connect from_op="Transpose" from_port="example set output" to_op="Union" to_port="example set 2"/> <connect from_op="Union" from_port="union" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="252"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
