Good afternoon,
I have a RM process which includes a PIVOT Operator. If I include a "breakpoint" in this operator it seems that pivot is well done (as I can see the Data), but the window in the "Process View" at the output of this Operator indicates Nr of Examples = 0... Why?? What should I do?
I include the code...
Thank you!!
BestRosana
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="338" width="644">
<operator activated="true" class="retrieve" compatibility="5.2.008" expanded="true" height="60" name="Retrieve (13)" width="90" x="45" y="120">
<parameter key="repository_entry" value="../InputData/Agoust/PPI/ArcAnl_20120822031500"/>
<operator activated="true" class="rename" compatibility="5.2.008" expanded="true" height="76" name="Rename (13)" width="90" x="179" y="120">
<parameter key="old_name" value="att2"/>
<parameter key="new_name" value="caID"/>
<list key="rename_additional_attributes">
<parameter key="att6" value="SysDate"/>
<parameter key="att13" value="ucState"/>
</list>
<operator activated="true" class="nominal_to_date" compatibility="5.2.008" expanded="true" height="76" name="Nominal to Date (13)" width="90" x="313" y="120">
<parameter key="attribute_name" value="SysDate"/>
<parameter key="date_type" value="date_time"/>
<parameter key="date_format" value="dd/mm/yy hh:mm"/>
<operator activated="true" class="pivot" compatibility="5.2.008" expanded="true" height="76" name="Pivot" width="90" x="447" y="120">
<parameter key="group_attribute" value="SysDate"/>
<parameter key="index_attribute" value="caID"/>
<parameter key="skip_constant_attributes" value="false"/>
<connect from_op="Retrieve (13)" from_port="output" to_op="Rename (13)" to_port="example set input"/>
<connect from_op="Rename (13)" from_port="example set output" to_op="Nominal to Date (13)" to_port="example set input"/>
<connect from_op="Nominal to Date (13)" from_port="example set output" to_op="Pivot" to_port="example set input"/>
<connect from_op="Pivot" from_port="example set output" to_port="result 1"/>
</process>
</process>
