<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="661" width="1021"> <operator activated="true" class="retrieve" compatibility="5.2.008" expanded="true" height="60" name="Retrieve" width="90" x="45" y="75"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="set_role" compatibility="5.2.008" expanded="true" height="76" name="Set Role" width="90" x="45" y="165"> <parameter key="name" value="a2"/> <parameter key="target_role" value="ignore2"/> <list key="set_additional_roles"> <parameter key="a3" value="ignore3"/> <parameter key="a4" value="ignore4"/> </list> </operator> <operator activated="true" class="detect_outlier_distances" compatibility="5.2.008" expanded="true" height="76" name="Detect Outlier (Distances)" width="90" x="246" y="75"/> <operator activated="true" class="set_role" compatibility="5.2.008" expanded="true" height="76" name="Set Role (2)" width="90" x="246" y="165"> <parameter key="name" value="a2"/> <list key="set_additional_roles"> <parameter key="a3" value="regular"/> <parameter key="a4" value="regular"/> </list> </operator> <connect from_op="Retrieve" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Detect Outlier (Distances)" to_port="example set input"/> <connect from_op="Detect Outlier (Distances)" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
