"Reporting - Scatter Multiple - Points and Lines"
To generate a report, i would like to include a scatter plot with multiple attributes and use lines rather than points.
In Reporting, plotter = Scatter Multiple, there is a list for "scatter multiple points and lines".How should this be used?
The editor shows only two columns with check boxes for points and lines. The column for the attribute id seems to be missing in this dialog. When saved, the xml representation of these parameters have a key and value pair, but the key appears to be true/false for the points check box, and the value is true/false for the lines checkbox. A second observation is that the checked boxes are not saved correctly (i.e. are returned to the default when reopening the Configuration Report dialog again.
Did anyone figure out how this should work/or should work at all?
