<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.005"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.005" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.005" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="75"> <list key="attribute_values"> <parameter key="a" value="1"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.005" expanded="true" height="60" name="Generate Data by User Specification (4)" width="90" x="45" y="525"> <list key="attribute_values"> <parameter key="a" value="3"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.005" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="45" y="165"> <list key="attribute_values"> <parameter key="a" value="1"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.005" expanded="true" height="60" name="Generate Data by User Specification (3)" width="90" x="45" y="255"> <list key="attribute_values"> <parameter key="a" value="1"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.005" expanded="true" height="60" name="Generate Data by User Specification (5)" width="90" x="45" y="345"> <list key="attribute_values"> <parameter key="a" value="1"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.005" expanded="true" height="60" name="Generate Data by User Specification (6)" width="90" x="45" y="435"> <list key="attribute_values"> <parameter key="a" value="2"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="5.3.005" expanded="true" height="166" name="Append" width="90" x="179" y="165"/> <operator activated="true" class="discretize_by_frequency" compatibility="5.3.005" expanded="true" height="94" name="Discretize" width="90" x="313" y="120"> <parameter key="number_of_bins" value="3"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Generate Data by User Specification (4)" from_port="output" to_op="Append" to_port="example set 6"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Generate Data by User Specification (3)" from_port="output" to_op="Append" to_port="example set 3"/> <connect from_op="Generate Data by User Specification (5)" from_port="output" to_op="Append" to_port="example set 4"/> <connect from_op="Generate Data by User Specification (6)" from_port="output" to_op="Append" to_port="example set 5"/> <connect from_op="Append" from_port="merged set" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.005"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.005" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.005" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="75"> <list key="attribute_values"> <parameter key="a" value="1"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.005" expanded="true" height="60" name="Generate Data by User Specification (4)" width="90" x="45" y="525"> <list key="attribute_values"> <parameter key="a" value="3"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.005" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="45" y="165"> <list key="attribute_values"> <parameter key="a" value="1"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.005" expanded="true" height="60" name="Generate Data by User Specification (3)" width="90" x="45" y="255"> <list key="attribute_values"> <parameter key="a" value="1"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.005" expanded="true" height="60" name="Generate Data by User Specification (5)" width="90" x="45" y="345"> <list key="attribute_values"> <parameter key="a" value="1"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.005" expanded="true" height="60" name="Generate Data by User Specification (6)" width="90" x="45" y="435"> <list key="attribute_values"> <parameter key="a" value="2"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="5.3.005" expanded="true" height="166" name="Append" width="90" x="179" y="165"/> <operator activated="true" class="aggregate" compatibility="5.3.005" expanded="true" height="76" name="Aggregate" width="90" x="313" y="210"> <parameter key="use_default_aggregation" value="true"/> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="a"/> <parameter key="default_aggregation_function" value="mode"/> <list key="aggregation_attributes"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.3.005" expanded="true" height="60" name="Extract Macro" width="90" x="380" y="120"> <parameter key="macro" value="mode"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="mode(a)"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.3.005" expanded="true" height="76" name="Filter Examples" width="90" x="447" y="210"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="a=%{mode}"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.3.005" expanded="true" height="60" name="Extract Macro (3)" width="90" x="581" y="165"> <parameter key="macro" value="modecount"/> <parameter key="attribute_name" value="mode(a)"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.3.005" expanded="true" height="60" name="Extract Macro (2)" width="90" x="447" y="345"> <parameter key="macro" value="count"/> <list key="additional_macros"/> </operator> <operator activated="true" class="set_macro" compatibility="5.3.005" expanded="true" height="76" name="Set Macro" width="90" x="581" y="345"> <parameter key="macro" value="bincount"/> <parameter key="value" value="3"/> </operator> <operator activated="true" class="branch" compatibility="5.3.005" expanded="true" height="76" name="Branch" width="90" x="581" y="435"> <parameter key="condition_type" value="expression"/> <parameter key="condition_value" value="%{modecount}>=2*%{count}/%{bincount}"/> <process expanded="true"> <operator activated="true" class="add_noise" compatibility="5.3.005" expanded="true" height="94" name="Add Noise" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="a"/> <parameter key="label_noise" value="0.0"/> <parameter key="default_attribute_noise" value="1.0E-9"/> <list key="noise"/> </operator> <connect from_port="condition" to_op="Add Noise" to_port="example set input"/> <connect from_op="Add Noise" from_port="example set output" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> <process expanded="true"> <connect from_port="condition" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> </operator> <operator activated="true" class="discretize_by_frequency" compatibility="5.3.005" expanded="true" height="94" name="Discretize" width="90" x="782" y="390"> <parameter key="number_of_bins" value="%{bincount}"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Generate Data by User Specification (4)" from_port="output" to_op="Append" to_port="example set 6"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Generate Data by User Specification (3)" from_port="output" to_op="Append" to_port="example set 3"/> <connect from_op="Generate Data by User Specification (5)" from_port="output" to_op="Append" to_port="example set 4"/> <connect from_op="Generate Data by User Specification (6)" from_port="output" to_op="Append" to_port="example set 5"/> <connect from_op="Append" from_port="merged set" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Aggregate" from_port="original" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Extract Macro (3)" to_port="example set"/> <connect from_op="Filter Examples" from_port="original" to_op="Extract Macro (2)" to_port="example set"/> <connect from_op="Extract Macro (2)" from_port="example set" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Branch" to_port="condition"/> <connect from_op="Branch" from_port="input 1" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_port="result 1"/> <connect from_op="Discretize" from_port="original" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
