marcin.blachnik wrote:HelloI'd like to notice a problem with Select Attributes operator with "numeric_value_filter". Setting the "numeric condition" parameter RapidMiner displays the "Process Faild" window with the appropriat message string. It even doesn't work with the "Tutorial process"
By the way I also have some problems with the "Normalize" operator when using the "right click" and "Show ExampleSet Results" on the output port of any operator before the Normalize operator the displayed exampleSet includes the normalized attributes instead of original values. lead to an erroneous understanding of the results
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="116" width="480"> <operator activated="true" class="generate_data" compatibility="5.2.008" expanded="true" height="60" name="Generate Data" width="90" x="179" y="30"> <parameter key="number_examples" value="10"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.2.008" expanded="true" height="76" name="Select Attributes" width="90" x="380" y="30"> <parameter key="attribute_filter_type" value="numeric_value_filter"/> <parameter key="numeric_condition" value="> -9.5"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="359" width="663"> <operator activated="true" class="retrieve" compatibility="5.3.000" expanded="true" height="60" name="Labor-Negotiations" width="90" x="179" y="120"> <parameter key="repository_entry" value="//Samples/data/Labor-Negotiations"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.000" expanded="true" height="76" name="Select Attributes" width="90" x="380" y="120"> <parameter key="attribute_filter_type" value="numeric_value_filter"/> <parameter key="attribute" value="working-hours"/> <parameter key="attributes" value="|wage-inc-1st|wage-inc-2nd|wage-inc-3rd"/> <parameter key="regular_expression" value="w.*|.*y.*"/> <parameter key="use_except_expression" value="true"/> <parameter key="except_regular_expression" value=".*[0-9].*"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="true"/> <parameter key="except_value_type" value="real"/> <parameter key="block_type" value="value_series_end"/> <parameter key="except_block_type" value="value_series_end"/> <parameter key="numeric_condition" value="< 5&&>0"/> <parameter key="include_special_attributes" value="true"/> </operator> <connect from_op="Labor-Negotiations" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/> <connect from_op="Select Attributes" from_port="original" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
marcin.blachnik wrote:What is interesting that I've checked the "Tutorial Process" avaliable in the development version (RM 5.3) and it also didn't work because of the space, so if you won't update the operator before the new release of RM please correct the "Tutorial Process"
