[SOLVED]How to get the computational time for different modules in a process
User: "winecoding"
New Altair Community Member
Updated by Jocelyn
I have a workflow to perform document processing for a collection of plain text files. This workflow consists of three sub-processes
1) Tokenize
2) TransformCase
3) Filter token by length
I am trying to log the following information
1) The total computational time for the whole document processing workflow
2) The computational time for each three sub-processes
Here is the process I created.  For illustration purposes, I just use 4 text files as input. In this process, I capture “CPU-Time” and “Time” in the log.
<process version="5.2.008">
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
 <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
   <process expanded="true" height="341" width="681">
     <operator activated="true" class="select_subprocess" compatibility="5.2.008" expanded="true" height="94" name="Select Subprocess" width="90" x="112" y="30">
       <process expanded="true" height="406" width="346">
         <operator activated="true" class="text:process_document_from_file" compatibility="5.2.004" expanded="true" height="76" name="Process Documents from Files (3)" width="90" x="246" y="75">
           <list key="text_directories">
             <parameter key="Responsive" value="C:\Desktop\testdata"/>
           </list>
           <parameter key="vector_creation" value="Binary Term Occurrences"/>
           <process expanded="true" height="431" width="697">
             <operator activated="true" class="select_subprocess" compatibility="5.2.008" expanded="true" height="94" name="subprocess1" width="90" x="45" y="30">
               <process expanded="true" height="406" width="413">
                 <operator activated="true" class="text:tokenize" compatibility="5.2.004" expanded="true" height="60" name="Tokenize" width="90" x="246" y="165"/>
                 <connect from_port="input 1" to_op="Tokenize" to_port="document"/>
                 <connect from_op="Tokenize" from_port="document" to_port="output 1"/>
                 <portSpacing port="sink_output 1" spacing="0"/>
                 <portSpacing port="sink_output 2" spacing="0"/>
                 <portSpacing port="sink_output 3" spacing="0"/>
               </process>
               <process expanded="true">
               </process>
             <operator activated="true" class="select_subprocess" compatibility="5.2.008" expanded="true" height="94" name="subprocess2" width="90" x="246" y="75">
               <process expanded="true" height="388" width="314">
                 <operator activated="true" class="text:transform_cases" compatibility="5.2.004" expanded="true" height="60" name="Transform Cases" width="90" x="151" y="71"/>
                 <connect from_port="input 1" to_op="Transform Cases" to_port="document"/>
                 <connect from_op="Transform Cases" from_port="document" to_port="output 1"/>
               </process>
               </process>
             <operator activated="true" class="select_subprocess" compatibility="5.2.008" expanded="true" height="94" name="subprocess3" width="90" x="447" y="30">
               <process expanded="true" height="388" width="346">
                 <operator activated="true" class="text:filter_by_length" compatibility="5.2.004" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="239" y="58">
                   <parameter key="min_chars" value="1"/>
                   <parameter key="max_chars" value="200"/>
                 <connect from_port="input 1" to_op="Filter Tokens (by Length)" to_port="document"/>
                 <connect from_op="Filter Tokens (by Length)" from_port="document" to_port="output 1"/>
               </process>
               </process>
             <operator activated="true" class="log" compatibility="5.2.008" expanded="true" height="112" name="Log" width="90" x="313" y="255">
               <list key="log">
                 <parameter key="tokenCPU" value="operator.Tokenize.value.cpu-time"/>
                 <parameter key="transformCPU" value="operator.Transform Cases.value.cpu-time"/>
                 <parameter key="filterCPU" value="operator.Filter Tokens (by Length).value.cpu-time"/>
                 <parameter key="tokenTime" value="operator.Tokenize.value.time"/>
                 <parameter key="transformTime" value="operator.Transform Cases.value.time"/>
                 <parameter key="filterTime" value="operator.Filter Tokens (by Length).value.time"/>
               </list>
             <connect from_port="document" to_op="subprocess1" to_port="input 1"/>
             <connect from_op="subprocess1" from_port="output 1" to_op="subprocess2" to_port="input 1"/>
             <connect from_op="subprocess1" from_port="output 2" to_op="Log" to_port="through 1"/>
             <connect from_op="subprocess2" from_port="output 1" to_op="subprocess3" to_port="input 1"/>
             <connect from_op="subprocess2" from_port="output 2" to_op="Log" to_port="through 2"/>
             <connect from_op="subprocess3" from_port="output 1" to_port="document 1"/>
             <connect from_op="subprocess3" from_port="output 2" to_op="Log" to_port="through 3"/>
             <connect from_op="Log" from_port="through 1" to_port="document 2"/>
             <portSpacing port="sink_document 3" spacing="0"/>
           </process>
         <connect from_port="input 1" to_op="Process Documents from Files (3)" to_port="word list"/>
         <connect from_op="Process Documents from Files (3)" from_port="example set" to_port="output 1"/>
       </process>
     <operator activated="true" class="log" compatibility="5.2.008" expanded="true" height="76" name="Log-DP" width="90" x="380" y="210">
       <list key="log">
         <parameter key="pdCPUTime" value="operator.Process Documents from Files (3).value.cpu-time"/>
         <parameter key="pdTime" value="operator.Process Documents from Files (3).value.time"/>
       </list>
     <connect from_op="Select Subprocess" from_port="output 1" to_port="result 2"/>
     <connect from_op="Select Subprocess" from_port="output 2" to_op="Log-DP" to_port="through 1"/>
     <connect from_op="Log-DP" from_port="through 1" to_port="result 1"/>
   </process>
</process>
Based on this result, I have several questions:
1) Why the logged information are so different for different runs?  And the first experiment run even has zero value for all three subprocesses.
2) I have four files, why the log information for three sub-processes has eight rows?
3) In Rapidminer, the CPU-time is measured in millisecond; What is measures in “Time” from log?
Thanks a lot.
1 - 6 of 61
    User: "MariusHelf"
    I think the text of your post does not match the process you posted (I only see one subprocess, and the log file contains only one row because it placed on the top level of the process).
    About the times: if I remember correctly, the CPU time is measured in microseconds, the time in milliseconds.
    Btw, in RapidMiner we call the modules "operators" :)
    Best, Marius
    User: "winecoding"
    OP
    Hi Marius,
    Thanks for answering my question. Please make “text directories” option  of operator “Process Documents From Files” to point to a local directory which contains some text files. It will generate two log outputs.
    On my machine, I run this process four times. I recorded the two log outputs for each of these four experiment runs.
    The first run:
    log for the "process document" operator, the whole workflow
    pdCPUTime pdTime
    31200200 63
    log for the three sub-processes
    tokenCPU transformCPU filterCPU tokenTime transformTime filterTime
    0 0 0 0 0 0
    15600100 15600100 15600100 16 16 16
    0 0 0 0 0 0
    0 0 0 0 0 0
    0 0 0 0 0 0
    0 0 0 0 0 0
    0 0 0 0 0 0
    0 0 0 0 0 0
    The second run:
    pdCPUTime pdTime
    15600100 390
    0 0 0 0 0 0
    0 0 0 16 16 16
    0 0 0 0 0 0
    0 0 0 0 0 0
    0 0 0 0 0 0
    0 0 0 0 0 0
    0 0 0 0 0 0
    0 0 0 0 0 0
    The third run:
    pdCPUTime pdTime
    46800300 62
    0 0 0 0 0 0
    15600100 0 0 15 0 0
    0 0 0 0 0 0
    0 0 0 0 0 0
    0 0 0 0 0 0
    0 0 0 0 0 0
    0 0 0 0 0 0
    0 0 0 0 0 0
    The fourth run
    pdCPUTime pdTime
    31200200 47
    0 0 0 0 0 0
    0 0 0 0 0 0
    0 0 0 16 16 16
    0 0 0 0 0 0
    0 0 0 0 0 0
    0 0 0 0 0 0
    0 0 0 0 0 0
    0 0 0 0 0 0
    From these results, we can see the CPU time for the three sub-processes even can get 0 for some experiments. But it cannot equal to zero.
    Secondly, we always get 8 rows for the log output of sub-processes. If I change the number of documents to 10, I will get 20 rows. Looks like the number of rows always double the number of input documents. I am not very clear where does this relationship come from?
    In addition, the microsecond is 1/1000 of millisecond,  But the result does not match this relationship. For instance, in the second run, the pdCPUTime = 15600100 microseconds, and pdTime=390 milliseconds   It seems to me that pdTime should equal to 15600 milliseonds instead.
    Thanks.
    User: "MariusHelf"
    Sorry, I missed the second log operator in the depths of the process .
    I looked it up in the code, the CPU time is in nanoseconds, not microseconds.
    Still, the numbers don't make always sense. FYI, we are using ManagementFactory.getThreadMXBean().getThreadCpuTime(Thread.currentThread().getId()) to calculate the cpu time, and the documentation says: "Returns the total CPU time for a thread of the specified ID in nanoseconds. The returned value is of nanoseconds precision but not necessarily nanoseconds accuracy."
    Maybe it has problems with these small times... on longer running operators it seems to deliver reasonable output - see the outer log operator.
    Best, Marius
    User: "MariusHelf"
    And I forgot: the inner process of Process Documents is executed twice per document, because the current implementation first performs  a full data scan to create the wordlist vector, and then, in a second run, creates the output attributes.
    User: "winecoding"
    OP
    Marius, Thanks.
    I still have one question:
    As you mentioned, cpu time is in nanoseconds and time is in milliseconds. But one of the experiments shows that the CPU time and Time for a single process  as follows
    pdCPUTime  pdTime
    31200200  47
    It looks like pdCPUTime does not equal to pdTime * 1000000
    User: "MariusHelf"
    Finally I can say: you are right, but it is supposed to be like that :)
    The CPU time shows how long the cpu has been used by that operator. But since you are running a multi-threading operating system, the cpu can also be used by other processes while the operator is executed, and thus the operator may take longer than it uses the cpu. In addition, if the operator performs network operations or accesses the disk, it needs to wait for responses from the respective devices, where it consumes time, but does not use the cpu.
    Best,
    Marius
