<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="416" width="749"> <operator activated="true" class="generate_data" compatibility="5.3.000" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="target_function" value="random classification"/> <parameter key="number_of_attributes" value="1"/> </operator> <operator activated="true" class="generate_empty_attribute" compatibility="5.3.000" expanded="true" height="76" name="Generate Empty Attribute" width="90" x="179" y="30"> <parameter key="name" value="trend_attr"/> </operator> <operator activated="true" class="set_macro" compatibility="5.3.000" expanded="true" height="76" name="Set Macro" width="90" x="313" y="30"> <parameter key="macro" value="delta"/> <parameter key="value" value="2"/> </operator> <operator activated="true" class="loop_examples" compatibility="5.3.000" expanded="true" height="94" name="Loop Examples" width="90" x="447" y="30"> <process expanded="true" height="434" width="767"> <operator activated="true" class="branch" compatibility="5.3.000" expanded="true" height="76" name="Branch" width="90" x="45" y="30"> <parameter key="condition_type" value="expression"/> <parameter key="condition_value" value="%{example} >= 2"/> <process expanded="true" height="434" width="358"> <operator activated="true" class="generate_macro" compatibility="5.3.000" expanded="true" height="76" name="Generate Macro" width="90" x="45" y="30"> <list key="function_descriptions"> <parameter key="prev" value="%{example}-1"/> </list> </operator> <operator activated="true" class="extract_macro" compatibility="5.3.000" expanded="true" height="60" name="Extract Macro (2)" width="90" x="45" y="120"> <parameter key="macro" value="v1"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="att1"/> <parameter key="example_index" value="%{prev}"/> <list key="additional_macros"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.3.000" expanded="true" height="60" name="Extract Macro" width="90" x="179" y="120"> <parameter key="macro" value="v2"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="att1"/> <parameter key="example_index" value="%{example}"/> <list key="additional_macros"/> </operator> <operator activated="true" class="generate_macro" compatibility="5.3.000" expanded="true" height="76" name="Generate Macro (2)" width="90" x="45" y="210"> <list key="function_descriptions"> <parameter key="trend" value="if(abs(%{v2}-%{v1}) > %{delta}, sgn(%{v2}-%{v1}), 0)"/> </list> </operator> <operator activated="true" class="set_data" compatibility="5.3.000" expanded="true" height="76" name="Set Data" width="90" x="179" y="210"> <parameter key="example_index" value="%{example}"/> <parameter key="attribute_name" value="trend_attr"/> <parameter key="value" value="%{trend}"/> <list key="additional_values"/> </operator> <connect from_port="condition" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Extract Macro (2)" to_port="example set"/> <connect from_op="Extract Macro (2)" from_port="example set" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Generate Macro (2)" to_port="through 1"/> <connect from_op="Generate Macro (2)" from_port="through 1" to_op="Set Data" to_port="example set input"/> <connect from_op="Set Data" from_port="example set output" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> <process expanded="true" height="434" width="358"> <connect from_port="condition" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Branch" to_port="condition"/> <connect from_op="Branch" from_port="input 1" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Generate Empty Attribute" to_port="example set input"/> <connect from_op="Generate Empty Attribute" from_port="example set output" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="example set" to_port="result 1"/> <connect from_op="Loop Examples" from_port="output 1" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
