Hi everyone,
How to continue running when crashing the software?
Thanks.
Hello!First do a geometry check. Use the section plane tool.
Some geometry problems to avoid:
- Areas with a thickness of 0. Also avoid super-thin areas (0.1/0.2mm)
- Air vents, generally cause problems due to the thin volume
- No connection between components. Partial connection between components too. Avoid spaces between components
- Flash defects. Avoid areas where the two halves of the mold collide
Check the settings:
- Check that the units used are in accordance
- Check that the mesh size is adequate. We recommend using a minimum of 3 elements in thin areas
- The temperature of the material must not be lower than the solidification temperature
- Check if your machine has memory and the minimum requirements
