I started rapid Miner and I select to save as the new empty process.
I write a name like sem and I received the following error, which sounds Greek to me. Can anyone explain this?
Thank you in advance
Enter a brief description of what happened into this text field. Please also describe the purpose of your process definition because this cannot always be concluded from the process setup (if applicable).
RapidMiner: 5.2.008
Parallel Processing: 5.1.000
Text Processing: 5.2.004
PMML: 5.2.000
WordNet: 5.2.000
Weka: 5.1.001
PaREn Wizard: 5.1.001
Community: 5.1.000
Web Mining: 5.2.003
Reporting: 5.2.000
Series: 5.2.000
Stack trace:
Exception: java.io.IOException
Message: Cannot store process at //tsimaras/seminars: Cannot write C:\Program Files\Rapid-I\RapidMiner5\seminars.rmp: java.io.FileNotFoundException: C:\Program Files\Rapid-I\RapidMiner5\seminars.rmp (Access is denied)
Stack trace:
com.rapidminer.RepositoryProcessLocation.store(RepositoryProcessLocation.java:109)
com.rapidminer.Process.save(Process.java:1011)
com.rapidminer.gui.actions.SaveAction.save(SaveAction.java:60)
com.rapidminer.gui.actions.SaveAsAction.saveAs(SaveAsAction.java:81)
com.rapidminer.gui.actions.SaveAsAction.actionPerformed(SaveAsAction.java:57)
javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
javax.swing.DefaultButtonModel.setPressed(Unknown Source)
javax.swing.AbstractButton.doClick(Unknown Source)
javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
java.awt.Component.processMouseEvent(Unknown Source)
javax.swing.JComponent.processMouseEvent(Unknown Source)
java.awt.Component.processEvent(Unknown Source)
java.awt.Container.processEvent(Unknown Source)
java.awt.Component.dispatchEventImpl(Unknown Source)
java.awt.Container.dispatchEventImpl(Unknown Source)
java.awt.Component.dispatchEvent(Unknown Source)
java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
java.awt.Window.dispatchEventImpl(Unknown Source)
java.awt.EventQueue.dispatchEventImpl(Unknown Source)
java.awt.EventQueue.access$000(Unknown Source)
java.awt.EventQueue$1.run(Unknown Source)
java.security.AccessController.doPrivileged(Native Method)
java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
java.awt.EventQueue$2.run(Unknown Source)
java.awt.EventQueue.dispatchEvent(Unknown Source)
java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
java.awt.EventDispatchThread.pumpEvents(Unknown Source)
java.awt.EventDispatchThread.run(Unknown Source)
Cause:Exception: com.rapidminer.repository.RepositoryException
Message: Cannot write C:\Program Files\Rapid-I\RapidMiner5\seminars.rmp: java.io.FileNotFoundException: C:\Program Files\Rapid-I\RapidMiner5\seminars.rmp (Access is denied)
Stack trace:
com.rapidminer.repository.local.SimpleProcessEntry.storeXML(SimpleProcessEntry.java:58)
com.rapidminer.RepositoryProcessLocation.store(RepositoryProcessLocation.java:101)
Cause:Exception: java.io.FileNotFoundException
Message: C:\Program Files\Rapid-I\RapidMiner5\seminars.rmp (Access is denied)
Stack trace:
java.io.FileOutputStream.open(Native Method)
java.io.FileOutputStream.<init>(Unknown Source)
java.io.FileWriter.<init>(Unknown Source)
com.rapidminer.tools.Tools.writeTextFile(Tools.java:732)
com.rapidminer.repository.local.SimpleProcessEntry.storeXML(SimpleProcessEntry.java:56)
Process:
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<parameter key="parallelize_main_process" value="false"/>
<process expanded="true" height="-20" width="-50">
</process>
</process>
System properties:
os properties:
os.name = Windows 7
os.version = 6.1
os.arch = x86
java properties:
java.home = C:\Program Files\Rapid-I\RapidMiner5\jre
java.endorsed.dirs = C:\Program Files\Rapid-I\RapidMiner5\jre\lib\endorsed
java.vendor.url = http://java.sun.com/
java.version = 1.6.0_31
java.vendor.url.bug = http://java.sun.com/cgi-bin/bugreport.cgi
java.runtime.name = Java(TM) SE Runtime Environment
java.specification.name = Java Platform API Specification
java.io.tmpdir = C:\Users\ezoulias\AppData\Local\Temp\
java.vm.info = mixed mode
java.vm.specification.name = Java Virtual Machine Specification
java.awt.printerjob = sun.awt.windows.WPrinterJob
java.specification.vendor = Sun Microsystems Inc.
java.vm.name = Java HotSpot(TM) Client VM
java.library.path = C:\Program Files\Rapid-I\RapidMiner5\jre\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Broadcom\Broadcom 802.11\Driver;C:\Program Files\WIDCOMM\Bluetooth Software\;C:\Program Files\Microsoft\Web Platform Installer\;C:\Program Files\OpenVPN\bin;.
java.class.version = 50.0
java.awt.graphicsenv = sun.awt.Win32GraphicsEnvironment
java.vm.specification.version = 1.0
java.ext.dirs = C:\Program Files\Rapid-I\RapidMiner5\jre\lib\ext;C:\Windows\Sun\Java\lib\ext
java.vm.vendor = Sun Microsystems Inc.
java.vm.version = 20.6-b01
java.class.path = lib/launcher.jar
java.vm.specification.vendor = Sun Microsystems Inc.
java.runtime.version = 1.6.0_31-b05
java.vendor = Sun Microsystems Inc.
java.specification.version = 1.6
RapidMiner Parameters:
ftp.nonProxyHosts =
ftp.proxyHost =
ftp.proxyPassword =
ftp.proxyPort =
ftp.proxySet = false
ftp.proxyUsername =
http.nonProxyHosts =
http.proxyHost =
http.proxyPassword =
http.proxyPort =
http.proxySet = false
http.proxyUsername =
https.proxyHost =
https.proxyPassword =
https.proxyPort =
https.proxySet = false
https.proxyUsername =
rapidminer.general.capabilities.warn = false
rapidminer.general.debugmode = false
rapidminer.general.encoding = SYSTEM
rapidminer.general.fractiondigits.numbers = 3
rapidminer.general.fractiondigits.percent = 2
rapidminer.general.locale.language = en
rapidminer.general.logfile.format = no
rapidminer.general.max_rows_used_for_guessing = 100
rapidminer.general.md_nominal_values_limit = 100
rapidminer.general.number_of_threads = 0
rapidminer.general.randomseed = 2001
rapidminer.general.timezone = SYSTEM
rapidminer.gui.add_breakpoint_results_to_history = false
rapidminer.gui.attributeeditor.columnlimit = 20
rapidminer.gui.attributeeditor.rowlimit = 50
rapidminer.gui.auto_switch_to_resultview = ask
rapidminer.gui.autowire_input = true
rapidminer.gui.autowire_output = true
rapidminer.gui.beep.breakpoint = true
rapidminer.gui.beep.error = true
rapidminer.gui.beep.success = true
rapidminer.gui.close_results_before_run = ask
rapidminer.gui.confirm_exit = true
rapidminer.gui.disconnect_on_disable = true
rapidminer.gui.evaluate_meta_data_for_sql_queries = true
rapidminer.gui.fetch_data_base_table_names = true
rapidminer.gui.log_level = CONFIG
rapidminer.gui.max_displayed_values = 50
rapidminer.gui.max_sortable_rows = 100000
rapidminer.gui.max_statistics_rows = 100000
rapidminer.gui.messageviewer.highlight.errors = 255,51,204
rapidminer.gui.messageviewer.highlight.logservice = 184,184,184
rapidminer.gui.messageviewer.highlight.notes = 51,151,51
rapidminer.gui.messageviewer.highlight.warnings = 51,51,255
rapidminer.gui.messageviewer.rowlimit = 1000
rapidminer.gui.plaf = system
rapidminer.gui.plotter.colors.classlimit = 10
rapidminer.gui.plotter.legend.classlimit = 20
rapidminer.gui.plotter.legend.maxcolor = 255,0,0
rapidminer.gui.plotter.legend.mincolor = 0,0,255
rapidminer.gui.plotter.matrixplot.size = 200
rapidminer.gui.plotter.rows.maximum = 5000
rapidminer.gui.processinfo.show = true
rapidminer.gui.resolve_relative_repository_locations = true
rapidminer.gui.result_display_type = docking
rapidminer.gui.save_before_run = ask
rapidminer.gui.save_on_process_creation = false
rapidminer.gui.savedialog = true
rapidminer.gui.snap_to_grid = true
rapidminer.gui.transfer_usagestats = ask
rapidminer.gui.undolist.size = 10
rapidminer.gui.update.check = true
rapidminer.init.plugins = true
rapidminer.init.plugins.location =
rapidminer.parallel.number_of_threads = 1
rapidminer.paren.wizard.meta_learning_model =
rapidminer.r.native_lib = C:\Program Files\Rapid-I\RapidMiner5\null\library\rJava\jri\jri.dll
rapidminer.r.user_fragment_documentations =
rapidminer.r.user_fragments =
rapidminer.tools.db.assist.show_only_standard_tables = true
rapidminer.tools.editor =
rapidminer.tools.gnuplot.command = gnuplot
rapidminer.tools.mail.default_recipient =
rapidminer.tools.mail.method = SMTP
rapidminer.tools.mail.process_duration_for_mail = 30
rapidminer.tools.myexperiment_url = http://www.myexperiment.org/
rapidminer.tools.sendmail.command = /usr/sbin/sendmail
rapidminer.tools.smtp.host =
rapidminer.tools.smtp.passwd =
rapidminer.tools.smtp.port =
rapidminer.tools.smtp.user =
rapidminer.update.check = true
rapidminer.update.incremental = true
rapidminer.update.to_home = true
rapidminer.update.url = http://rapidupdate.de:80/UpdateServer
rapidminer.version = 5.2.008
socksProxyHost =
socksProxyPort =
