<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="476" width="692"> <operator activated="true" class="read_excel" compatibility="5.2.006" expanded="true" height="60" name="Read Excel" width="90" x="45" y="75"> <parameter key="excel_file" value="D:\Μεταπτυχιακό\Διπλωματική\Union_of_all_examples.xls"/> <parameter key="imported_cell_range" value="A1:F8904"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="att0.true.integer.attribute"/> <parameter key="1" value="att1.true.integer.attribute"/> <parameter key="2" value="att2.true.integer.attribute"/> <parameter key="3" value="att3.true.integer.attribute"/> <parameter key="4" value="att4.true.integer.attribute"/> <parameter key="5" value="decision.true.binominal.label"/> </list> </operator> <operator activated="true" class="x_validation" compatibility="5.2.006" expanded="true" height="112" name="Validation" width="90" x="246" y="30"> <process expanded="true" height="413" width="330"> <operator activated="true" class="decision_tree" compatibility="5.2.006" expanded="true" height="76" name="Decision Tree" width="90" x="137" y="65"/> <connect from_port="training" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="413" width="330"> <operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model" width="90" x="45" y="75"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.2.006" expanded="true" height="76" name="Performance" width="90" x="179" y="75"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="imageprocessing:open_image" compatibility="1.4.001" expanded="true" height="60" name="Open Gray-scale Image" width="90" x="45" y="165"> <parameter key="filename" value="D:\Μεταπτυχιακό\Διπλωματική\filtered-images\11.jpg"/> <parameter key="set_mask" value="false"/> <parameter key="fitness" value="D:\Μεταπτυχιακό\Διπλωματική\filtered-images-fitness\11.jpg"/> </operator> <operator activated="true" class="multiply" compatibility="5.2.006" expanded="true" height="166" name="Multiply" width="90" x="45" y="300"/> <operator activated="true" class="imageprocessing:gaussian_blur" compatibility="1.4.001" expanded="true" height="60" name="Gaussian Blur (2)" width="90" x="447" y="390"> <parameter key="strength" value="4.0"/> </operator> <operator activated="true" breakpoints="after" class="imageprocessing:poi_generator" compatibility="1.4.001" expanded="true" height="60" name="Point of interest generator" width="90" x="179" y="165"> <parameter key="Points count" value="1500"/> <list key="Points Table"/> </operator> <operator activated="true" class="imageprocessing:contrast_adjuster" compatibility="1.4.001" expanded="true" height="60" name="contrast_adjuster" width="90" x="246" y="345"/> <operator activated="true" class="imageprocessing:gaussian_blur" compatibility="1.4.001" expanded="true" height="60" name="Gaussian Blur (3)" width="90" x="313" y="165"/> <operator activated="true" class="imageprocessing:gaussian_blur" compatibility="1.4.001" expanded="true" height="60" name="Gaussian Blur" width="90" x="313" y="255"/> <operator activated="true" class="imageprocessing:trainable_segmentation" compatibility="1.4.001" expanded="true" height="184" name="Trainable segmentation" width="90" x="447" y="120"> <parameter key="assign_label" value="by point label"/> <process expanded="true" height="422" width="692"> <operator activated="true" class="numerical_to_binominal" compatibility="5.2.006" expanded="true" height="76" name="Numerical to Binominal" width="90" x="112" y="75"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="include_special_attributes" value="true"/> <parameter key="min" value="255.0"/> <parameter key="max" value="255.0"/> </operator> <operator activated="true" class="decision_tree" compatibility="5.2.006" expanded="true" height="76" name="Decision Tree (2)" width="90" x="313" y="30"/> <operator activated="true" class="imageprocessing:open_image" compatibility="1.4.001" expanded="true" height="60" name="Open Gray-scale Image (2)" width="90" x="45" y="300"> <parameter key="filename" value="D:\Μεταπτυχιακό\Διπλωματική\filtered-images\21.jpg"/> <parameter key="set_mask" value="false"/> </operator> <operator activated="true" class="multiply" compatibility="5.2.006" expanded="true" height="94" name="Multiply (2)" width="90" x="246" y="255"/> <operator activated="true" class="imageprocessing:poi_generator" compatibility="1.4.001" expanded="true" height="60" name="Point of interest generator (2)" width="90" x="260" y="159"> <parameter key="Points count" value="300"/> <list key="Points Table"/> </operator> <operator activated="true" class="imageprocessing:trainable_segmentation" compatibility="1.4.001" expanded="true" height="112" name="Trainable segmentation (2)" width="90" x="380" y="255"> <parameter key="assign_label" value="by point label"/> <process expanded="true" height="413" width="692"> <operator activated="true" class="numerical_to_binominal" compatibility="5.2.006" expanded="true" height="76" name="Numerical to Binominal (2)" width="90" x="84" y="106"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="include_special_attributes" value="true"/> <parameter key="min" value="255.0"/> <parameter key="max" value="255.0"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.2.006" expanded="true" height="76" name="Generate Attributes" width="90" x="271" y="116"> <list key="function_descriptions"> <parameter key="decision" value="if(label==255,"cancer","no_cancer")"/> </list> </operator> <operator activated="true" class="decision_tree" compatibility="5.2.006" expanded="true" height="76" name="Decision Tree (3)" width="90" x="447" y="120"/> <connect from_port="example set" to_op="Numerical to Binominal (2)" to_port="example set input"/> <connect from_op="Numerical to Binominal (2)" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Decision Tree (3)" to_port="training set"/> <connect from_op="Decision Tree (3)" from_port="model" to_port="model"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> </process> </operator> <operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model (3)" width="90" x="447" y="75"> <list key="application_parameters"/> </operator> <connect from_port="example set" to_op="Numerical to Binominal" to_port="example set input"/> <connect from_op="Numerical to Binominal" from_port="example set output" to_op="Decision Tree (2)" to_port="training set"/> <connect from_op="Decision Tree (2)" from_port="model" to_op="Apply Model (3)" to_port="model"/> <connect from_op="Open Gray-scale Image (2)" from_port="grayscale image plus" to_op="Multiply (2)" to_port="input"/> <connect from_op="Multiply (2)" from_port="output 1" to_op="Point of interest generator (2)" to_port="img"/> <connect from_op="Multiply (2)" from_port="output 2" to_op="Trainable segmentation (2)" to_port="images 1"/> <connect from_op="Point of interest generator (2)" from_port="points of interest" to_op="Trainable segmentation (2)" to_port="points"/> <connect from_op="Trainable segmentation (2)" from_port="exampleSet" to_op="Apply Model (3)" to_port="unlabelled data"/> <connect from_op="Apply Model (3)" from_port="model" to_port="model"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> </process> </operator> <operator activated="true" class="apply_model" compatibility="5.2.006" expanded="true" height="76" name="Apply Model (2)" width="90" x="447" y="30"> <list key="application_parameters"/> </operator> <connect from_op="Read Excel" from_port="output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Open Gray-scale Image" from_port="grayscale image plus" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Point of interest generator" to_port="img"/> <connect from_op="Multiply" from_port="output 2" to_op="Trainable segmentation" to_port="images 1"/> <connect from_op="Multiply" from_port="output 3" to_op="contrast_adjuster" to_port="grayscale in"/> <connect from_op="Multiply" from_port="output 4" to_op="Gaussian Blur (3)" to_port="image plus"/> <connect from_op="Multiply" from_port="output 5" to_op="Gaussian Blur" to_port="image plus"/> <connect from_op="Multiply" from_port="output 6" to_op="Gaussian Blur (2)" to_port="image plus"/> <connect from_op="Gaussian Blur (2)" from_port="image plus" to_op="Trainable segmentation" to_port="images 5"/> <connect from_op="Point of interest generator" from_port="points of interest" to_op="Trainable segmentation" to_port="points"/> <connect from_op="contrast_adjuster" from_port="grayscale out" to_op="Trainable segmentation" to_port="images 2"/> <connect from_op="Gaussian Blur (3)" from_port="image plus" to_op="Trainable segmentation" to_port="images 3"/> <connect from_op="Gaussian Blur" from_port="image plus" to_op="Trainable segmentation" to_port="images 4"/> <connect from_op="Trainable segmentation" from_port="model" to_port="result 1"/> <connect from_op="Trainable segmentation" from_port="exampleSet" to_op="Apply Model (2)" to_port="unlabelled data"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process> [ /code]
