Hi
I face a problem with LibSVM operator. My problem in general is the classification of the customers' reviews in the online shop (in german). So, what I did so far:
1. Collected the reviews (200) in the excel sheet.
2. I built a text processing model only for the editing my training data (tokenization, stemming, filtering,etc.) and saved in another excel sheet. So, it is less then 200 reviews and I gave them labels . For the beginning, I want to do 2-class classification (fast delivery and xxx).
3. I built another model, which is for the classification with LibSVM. Here LibSVM wants numeric values, so before this operator I use NominalToNumerical operator.
4. When I apply test data, the result is bad. A lot of examples are misclassified.
I put also breakpoint before LibSVM in order to see what exactly does that NominalToNumerical operator. And it just gives unique numbers to training examples, so it cant work.
Now I'm thinking how to solve this problem or maybe I have to use other operator? By the way, whole data is in german.
Thanks in advance.
Best regards
Armen
Classification Model
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="386" width="815">
<operator activated="true" class="read_database" compatibility="5.2.008" expanded="true" height="60" name="Read Database (2)" width="90" x="45" y="165">
<parameter key="connection" value="sqlserver"/>
<parameter key="query" value="SELECT * FROM `test_schnell`"/>
<enumeration key="parameters"/>
<operator activated="true" class="read_excel" compatibility="5.2.008" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30">
<parameter key="excel_file" value="C:\Users\MP-TEST\Desktop\Rapid_Test\Klein.xls"/>
<parameter key="imported_cell_range" value="A1:B123"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations"/>
<parameter key="locale" value="German (Germany)"/>
<parameter key="0" value="Bewertung.true.text.attribute"/>
<parameter key="1" value="Label.true.text.label"/>
</list>
<operator activated="true" class="set_role" compatibility="5.2.008" expanded="true" height="76" name="Set Role" width="90" x="313" y="30">
<parameter key="name" value="Bewertung"/>
<list key="set_additional_roles">
<parameter key="Label" value="label"/>
</list>
<operator activated="true" class="nominal_to_numerical" compatibility="5.2.008" expanded="true" height="94" name="Nominal to Numerical" width="90" x="447" y="75">
<list key="comparison_groups"/>
<operator activated="true" class="support_vector_machine_libsvm" compatibility="5.2.008" expanded="true" height="76" name="SVM" width="90" x="648" y="30">
<list key="class_weights"/>
<operator activated="true" class="apply_model" compatibility="5.2.008" expanded="true" height="76" name="Apply Model" width="90" x="648" y="165">
<connect from_op="Read Database (2)" from_port="output" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Read Excel" from_port="output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Nominal to Numerical" to_port="example set input"/>
<connect from_op="Nominal to Numerical" from_port="example set output" to_op="SVM" to_port="training set"/>
<connect from_op="SVM" from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/>
<connect from_op="Apply Model" from_port="model" to_port="result 2"/>
</process>
</process>
Text Processing Model
<context>
<input/>
<output/>
<macros/>
</context>
<process expanded="true" height="375" width="756">
<operator activated="true" class="read_excel" compatibility="5.2.008" expanded="true" height="60" name="Read Excel" width="90" x="45" y="75">
<parameter key="excel_file" value="C:\Users\MP-TEST\Desktop\Rapid_Test\Training Data - Schnell.xls"/>
<parameter key="imported_cell_range" value="A1:B201"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
</list>
<operator activated="true" class="nominal_to_text" compatibility="5.2.008" expanded="true" height="76" name="Nominal to Text" width="90" x="179" y="120"/>
<operator activated="true" class="text:process_document_from_data" compatibility="5.2.004" expanded="true" height="76" name="Process Documents from Data" width="90" x="313" y="30">
<parameter key="prunde_below_percent" value="5.0"/>
<parameter key="prune_above_percent" value="100.0"/>
<list key="specify_weights"/>
<process expanded="true" height="386" width="774">
<operator activated="true" class="text:tokenize" compatibility="5.2.004" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30">
<parameter key="mode" value="specify characters"/>
<parameter key="characters" value=".:,:;:!:?:|:+-="/>
<operator activated="true" class="text:filter_by_length" compatibility="5.2.004" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="45" y="120">
<parameter key="max_chars" value="9999"/>
<operator activated="true" class="text:stem_dictionary" compatibility="5.2.004" expanded="true" height="76" name="Stem (Dictionary)" width="90" x="45" y="210">
<parameter key="file" value="C:\Users\MP-TEST\Desktop\Rapid_Test\Wörterbuch.TXT"/>
<operator activated="true" class="text:filter_stopwords_german" compatibility="5.2.004" expanded="true" height="60" name="Filter Stopwords (German)" width="90" x="246" y="120"/>
<operator activated="false" class="text:stem_german" compatibility="5.2.004" expanded="true" height="60" name="Stem (German)" width="90" x="313" y="30"/>
<operator activated="true" class="text:filter_tokens_by_content" compatibility="5.2.004" expanded="true" height="60" name="Filter Tokens (by Content)" width="90" x="380" y="210">
<parameter key="condition" value="contains match"/>
<parameter key="string" value="schnell "/>
<parameter key="regular_expression" value=".*schnell.*|.*liefer.*|.*gern.*|.*wieder.*|.*versand.*|.*ware.*|.*ordnung.*|"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Stem (Dictionary)" to_port="document"/>
<connect from_op="Stem (Dictionary)" from_port="document" to_op="Filter Stopwords (German)" to_port="document"/>
<connect from_op="Filter Stopwords (German)" from_port="document" to_op="Filter Tokens (by Content)" to_port="document"/>
<connect from_op="Filter Tokens (by Content)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="text:wordlist_to_data" compatibility="5.2.004" expanded="true" height="76" name="WordList to Data" width="90" x="313" y="210"/>
<operator activated="true" class="write_excel" compatibility="5.2.008" expanded="true" height="76" name="Write Excel" width="90" x="514" y="165">
<connect from_op="Read Excel" from_port="output" to_op="Nominal to Text" to_port="example set input"/>
<connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_port="result 2"/>
<connect from_op="Process Documents from Data" from_port="word list" to_op="WordList to Data" to_port="word list"/>
<connect from_op="WordList to Data" from_port="example set" to_op="Write Excel" to_port="input"/>
<connect from_op="Write Excel" from_port="through" to_port="result 1"/>
</process>
</process>
A part of my training Data after text processing
alles in ordnung alles perfekt und schnell nur zu empfehlen alles schnell und problemlos verlaufen anfragen werden sehr schnell beantwortet auch bei retouren sehr schnell die lieferung ging schnell und die verpackung ist im sehr guten zustand die ware wurde schnell und ordentlich verpackt geliefert einwandfreie ware gerne bei gelegenheit wieder mal gerne wieder gerne wieder gut verpackt und gute ware guter versand heute geliefert ich würde jederzeit wieder bei "mein paket" bestellen immer wieder gerne jederzeit wieder kontaktanfragen waren nicht nötig lieferung und service perfekt lieferzeit war 1 woche mit dem service zufrieden hätte auf ne schnellere e preis voll und ganz in ordnung preiswerte ware (terra 1 rasche lieferung einwandfreier ware schnell versandt schnelle lieferung schnelle lieferung und guter rucksack schnelle versendung der ware schneller versand sehr gerne wieder sehr schnell geliefert sehr schnelle lieferung sehr schnelle versand sichere lieferung mit dhl sogar schneller als versandbenachrichtigung super schneller versand super schneller versand (schneller geht es kaum) und schneller versand vom schnellen versand bis hin zum super leckerem getränk ware einwandfrei ware i ware ist wie beschrieben ware kam innerhalb weniger tage ware ok ware orginalverpackt ware und versand 1 ware wie beschrieben werde wieder hier kaufen wir waren mit dem anbieter sehr zufrieden alles in ordnung alles super immer wieder gerne alles waren in ordnung bestellung wurde sofort bearbeitet und wir hatten die lieferung innerhalb von 3 tagen bei uns blitzlieferung der artikel wurde zufriedenstellend und schnell versendet der preis für die ware ist ok die lieferung auch die ware ist schnell geliefert wurden |
xxxxxxxxxxxxschnelle lieferungschnelle lieferungschnelle lieferungxxxxxxxxxxxxxxxschnelle lieferungschnelle lieferungxxxxxxxxxxxxschnelle lieferungxxxxxxxxxxxxschnelle lieferungschnelle lieferungschnelle lieferungschnelle lieferungschnelle lieferungschnelle lieferungxxxschnelle lieferungschnelle lieferungschnelle lieferungxxxschnelle lieferungschnelle lieferungschnelle lieferungschnelle lieferungschnelle lieferungxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxschnelle lieferungschnelle lieferungschnelle lieferungxxxschnelle lieferungschnelle lieferung
The part of test data after text processing
bin sehr zufrieden danke das zelt ist einfach spitze dass das produkt eklig ist gern wieder gerne wieder gerne wieder jede meiner vielen anfragen vor der kauf wurden durch kuhnshop schnell und zu meiner zufriedenheit beantwortet jederzeit wieder kann ich weiterempfehlen lieferzeit top schnelle lieferung sehr schnelle lieferung sowohl bei der lieferung als auch bei der rücknahme super top preis verpackung versand war gut und angemessen schnell versand war sehr schnell vielen dank vorbildlicher service ware ok alles bestens alles hat hervorragend geklappt alles ohne probleme alles super alles super bin zufrieden alles war bestens alles wunderbar geklappt bin sehr zufrieden der anbieter kann ja nix dafür für den preis kann mann nichts falsch machen hat alles super geklappt keine bemängelung nur positiv zu meiner zufriedenheit kuhnshop zum zweiten mal bereits spitze liefert gute ergebnisse
