Hi !
Maybe I missed something obvious:
It seems to me that it is not possible to postprocess an
attribute coming from an aggregation task.
In the attached workflow I would like to do some calculations
on "sum(attr1)" but it fails. Do I need macros ?
Thanks for some hints in advance !
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="431" width="882">
<operator activated="true" class="generate_data" compatibility="5.2.008" expanded="true" height="60" name="Generate Data" width="90" x="45" y="210">
<parameter key="target_function" value="random classification"/>
<operator activated="true" class="aggregate" compatibility="5.2.008" expanded="true" height="76" name="Aggregate" width="90" x="179" y="75">
<parameter key="att1" value="sum"/>
</list>
<parameter key="group_by_attributes" value="label|"/>
<operator activated="true" class="generate_attributes" compatibility="5.2.008" expanded="true" height="76" name="Generate Attributes" width="90" x="447" y="75">
<parameter key="new_attrib" value="sum(att1) * 100"/>
</list>
<connect from_op="Generate Data" from_port="output" to_op="Aggregate" to_port="example set input"/>
<connect from_op="Aggregate" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
<connect from_op="Generate Attributes" from_port="original" to_port="result 2"/>
</process>
</process>
