<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="imageprocessing:bag_of_words" compatibility="1.3.003" expanded="true" height="60" name="Global Feature Extractor using Histograms" width="90" x="112" y="120"> <list key="categories"> <parameter key="city" value="C:\Users\Elena\Dropbox\Master\Thesis\mcio"/> </list> <process expanded="true"> <operator activated="true" breakpoints="after" class="imageprocessing:color_to_grayscale" compatibility="1.3.003" expanded="true" height="60" name="Color to grayscale" width="90" x="112" y="120"/> <operator activated="true" class="imageprocessing:feature_extraction_operator" compatibility="1.3.003" expanded="true" height="94" name="Local Feature Extractor" width="90" x="313" y="75"> <process expanded="true"> <operator activated="true" class="imageprocessing:bvlc" compatibility="1.3.003" expanded="true" height="60" name="BVLC" width="90" x="246" y="120"/> <connect from_port="grayscale 1" to_op="BVLC" to_port="grayscale image plus"/> <connect from_op="BVLC" from_port="feature" to_port="feature 1"/> <portSpacing port="source_grayscale 1" spacing="0"/> <portSpacing port="source_grayscale 2" spacing="0"/> <portSpacing port="sink_feature 1" spacing="0"/> <portSpacing port="sink_feature 2" spacing="0"/> </process> </operator> <connect from_port="img" to_op="Color to grayscale" to_port="color image plus"/> <connect from_op="Color to grayscale" from_port="grayscale image" to_op="Local Feature Extractor" to_port="images 1"/> <connect from_op="Local Feature Extractor" from_port="example set" to_port="example set"/> <portSpacing port="source_img" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <connect from_op="Global Feature Extractor using Histograms" from_port="example set hist" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
