<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="325" width="614"> <operator activated="true" class="imageprocessing:multiple_color_image_opener" compatibility="1.3.003" expanded="true" height="60" name="MCIO" width="90" x="380" y="30"> <list key="images"> <parameter key="true" value="D:\store\categorization\nature"/> <parameter key="false" value="D:\store\categorization\urban"/> </list> <parameter key="assign_label" value="true"/> <process expanded="true" height="702" width="1221"> <operator activated="true" class="imageprocessing:global_feature_extraction" compatibility="1.3.003" expanded="true" height="60" name="Global Feature Extractor from a Single Image" width="90" x="380" y="30"> <parameter key="include_position_filename" value="false"/> <process expanded="true" height="702" width="1221"> <operator activated="true" class="imageprocessing:statistics" compatibility="1.3.003" expanded="true" height="60" name="Global statistics" width="90" x="447" y="30"/> <operator activated="true" class="imageprocessing:histogram" compatibility="1.3.003" expanded="true" height="60" name="histogram" width="90" x="313" y="75"> <parameter key="Bins" value="32"/> </operator> <operator activated="true" class="imageprocessing:BIC" compatibility="1.3.003" expanded="true" height="76" name="BIC" width="90" x="313" y="165"/> <operator activated="true" class="imageprocessing:dLog_distance" compatibility="1.3.003" expanded="true" height="60" name="dLog" width="90" x="447" y="165"/> <operator activated="true" class="imageprocessing:color_model_operator" compatibility="1.3.003" expanded="true" height="60" name="ClrToGS" width="90" x="313" y="435"> <parameter key="Color component" value="Red"/> </operator> <operator activated="true" class="imageprocessing:obcf" compatibility="1.3.003" expanded="true" height="60" name="OBCF" width="90" x="447" y="435"/> <operator activated="true" class="imageprocessing:color_model_operator" compatibility="1.3.003" expanded="true" height="60" name="ClrToGS (2)" width="90" x="313" y="345"> <parameter key="Color component" value="Green"/> </operator> <operator activated="true" class="imageprocessing:obcf" compatibility="1.3.003" expanded="true" height="60" name="OBCF (2)" width="90" x="447" y="345"/> <operator activated="true" class="imageprocessing:color_model_operator" compatibility="1.3.003" expanded="true" height="60" name="ClrToGS (3)" width="90" x="313" y="255"> <parameter key="Color component" value="Blue"/> </operator> <operator activated="true" class="imageprocessing:obcf" compatibility="1.3.003" expanded="true" height="60" name="OBCF (3)" width="90" x="447" y="255"/> <connect from_port="color image plus 1" to_op="Global statistics" to_port="color image plus"/> <connect from_port="color image plus 2" to_op="histogram" to_port="color image plus"/> <connect from_port="color image plus 3" to_op="BIC" to_port="color image plus"/> <connect from_port="color image plus 4" to_op="ClrToGS" to_port="color image plus"/> <connect from_port="color image plus 5" to_op="ClrToGS (2)" to_port="color image plus"/> <connect from_port="color image plus 6" to_op="ClrToGS (3)" to_port="color image plus"/> <connect from_op="Global statistics" from_port="features" to_port="feature 1"/> <connect from_op="histogram" from_port="features" to_port="feature 2"/> <connect from_op="BIC" from_port="grayscale image plus Hist" to_op="dLog" to_port="grayscale image plus Hist"/> <connect from_op="dLog" from_port="features" to_port="feature 5"/> <connect from_op="ClrToGS" from_port="grayscale image plus" to_op="OBCF" to_port="grayscale image plus"/> <connect from_op="OBCF" from_port="features" to_port="feature 4"/> <connect from_op="ClrToGS (2)" from_port="grayscale image plus" to_op="OBCF (2)" to_port="grayscale image plus"/> <connect from_op="OBCF (2)" from_port="features" to_port="feature 6"/> <connect from_op="ClrToGS (3)" from_port="grayscale image plus" to_op="OBCF (3)" to_port="grayscale image plus"/> <connect from_op="OBCF (3)" from_port="features" to_port="feature 7"/> <portSpacing port="source_color image plus 1" spacing="0"/> <portSpacing port="source_color image plus 2" spacing="0"/> <portSpacing port="source_color image plus 3" spacing="0"/> <portSpacing port="source_color image plus 4" spacing="0"/> <portSpacing port="source_color image plus 5" spacing="0"/> <portSpacing port="source_color image plus 6" spacing="0"/> <portSpacing port="source_color image plus 7" spacing="0"/> <portSpacing port="sink_feature 1" spacing="0"/> <portSpacing port="sink_feature 2" spacing="0"/> <portSpacing port="sink_feature 3" spacing="0"/> <portSpacing port="sink_feature 4" spacing="0"/> <portSpacing port="sink_feature 5" spacing="0"/> <portSpacing port="sink_feature 6" spacing="0"/> <portSpacing port="sink_feature 7" spacing="0"/> <portSpacing port="sink_feature 8" spacing="0"/> </process> </operator> <connect from_port="color image plus" to_op="Global Feature Extractor from a Single Image" to_port="color image plus"/> <connect from_op="Global Feature Extractor from a Single Image" from_port="example set" to_port="Example set"/> <portSpacing port="source_color image plus" spacing="0"/> <portSpacing port="sink_Example set" spacing="0"/> </process> </operator> <connect from_op="MCIO" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
