<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.009"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.009" expanded="true" name="Process"> <process expanded="true" height="558" width="696"> <operator activated="true" class="generate_data" compatibility="5.2.009" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="target_function" value="sum"/> <parameter key="number_examples" value="10"/> <parameter key="number_of_attributes" value="1"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.2.009" expanded="true" height="76" name="Generate Attributes" width="90" x="179" y="30"> <list key="function_descriptions"> <parameter key="att1_group" value="att1"/> </list> </operator> <operator activated="true" class="discretize_by_bins" compatibility="5.2.009" expanded="true" height="94" name="Discretize" width="90" x="313" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="att1_group"/> <parameter key="number_of_bins" value="5"/> </operator> <operator activated="true" class="aggregate" compatibility="5.2.009" expanded="true" height="76" name="Aggregate" width="90" x="447" y="30"> <list key="aggregation_attributes"> <parameter key="att1" value="average"/> </list> <parameter key="group_by_attributes" value="|att1_group"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_port="result 1"/> <connect from_op="Aggregate" from_port="original" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
