<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.009"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.009" expanded="true" name="Process"> <process expanded="true" height="428" width="924"> <operator activated="true" class="generate_nominal_data" compatibility="5.2.009" expanded="true" height="60" name="Generate Nominal Data" width="90" x="112" y="30"/> <operator activated="true" class="loop_values" compatibility="5.2.009" expanded="true" height="76" name="Loop Values" width="90" x="246" y="30"> <parameter key="attribute" value="label"/> <process expanded="true" height="446" width="942"> <operator activated="true" breakpoints="after" class="filter_examples" compatibility="5.2.009" expanded="true" height="76" name="Filter Examples" width="90" x="112" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="label=%{loop_value}"/> </operator> <operator activated="true" class="subprocess" compatibility="5.2.009" expanded="true" height="76" name="Do whatever you want " width="90" x="313" y="30"> <process expanded="true"> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Do whatever you want " to_port="in 1"/> <connect from_op="Do whatever you want " from_port="out 1" to_port="out 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Loop Values" to_port="example set"/> <connect from_op="Loop Values" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
