<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.009"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.009" expanded="true" name="Process"> <process expanded="true" height="428" width="924"> <operator activated="true" class="generate_macro" compatibility="5.2.009" expanded="true" height="76" name="Generate Macro" width="90" x="45" y="75"> <list key="function_descriptions"> <parameter key="filename" value="date_str_custom(date_now(), "yyyy_MM_dd")"/> </list> </operator> <operator activated="true" breakpoints="after" class="print_to_console" compatibility="5.2.009" expanded="true" height="76" name="Print to Console" width="90" x="179" y="75"> <parameter key="log_value" value="Macro value: "%{filename}""/> </operator> <operator activated="true" class="reporting:generate_report" compatibility="5.2.001" expanded="true" height="76" name="Generate Report" width="90" x="380" y="75"> <parameter key="pdf_output_file" value="%{filename}"/> </operator> <connect from_op="Generate Macro" from_port="through 1" to_op="Print to Console" to_port="through 1"/> <connect from_op="Print to Console" from_port="through 1" to_op="Generate Report" to_port="through 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
