Hi everyone,
I read tetra meshing parameters in help but I don't still understand this. Can you share the documents or the example about some options in tetra meshing parameters?
Thanks,
I would recommend taking a look at this link, which explains these parameters: https://2022.help.altair.com/2022.2/hwdesktop/hm/topics/pre_processing/meshing/mesh_controls_type_volume_meshing_r.htm?zoom_highlight=tetra+mesh
Hi Arthur,
Why are uniform layers of interpolate option= octree=delaunay=-1?
In your link, an octree/Delaunay is a tetra meshing method. So, another option using normal tetra meshing, right? How to define Max Octant Size and Min Octant Size in the tetra mesh parameters panel?
Can you share the example comparison between these options?
Thanks.
