Marius wrote:Hi,if you have a X-Validation, it provides the first three performance measure of its inner Performance operator as log values (performance1, 2 and 3).
If you use the Performance (Binominal Classification) operator, you can select false positive, false negative etc. and thus get the values of the confusion matrix.
Currently, there is this limitation that you can only log three performance values from the X-Validation. The next release of RapidMiner, however, will feature a Performance to Data operator, which will convert the complete performance vector to an example set, such that you can get all the values of the Performance operator. The dataset will have the format Performance Measure - Value, where Performance Measure is one of the performance measures selected in the Performance operator.
Best, Marius
fritmore wrote:Yes thats nice, but there is no option to get directly TP and FP for a certain class or percentages. One has to filter examples, generate attributes ,extract macros....that's how I calculate what I need... and it works fine ^_^(...)I have not tried that. Is this available only for the binary case then?
Sounds good. Hope you squeeze in the option for an arbitrary field of the confusion m.cheersf
