Why would the following process output 'a/b/c' rather than just 'c'?
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="659" width="1042">
<operator activated="true" class="set_macro" compatibility="5.2.008" expanded="true" height="76" name="Set Macro" width="90" x="45" y="75">
<parameter key="macro" value="path"/>
<parameter key="value" value="a/b/c"/>
<operator activated="true" class="generate_macro" compatibility="5.2.008" expanded="true" height="76" name="Generate Macro" width="90" x="179" y="75">
<parameter key="path_ending" value="replaceAll("%{path}","^.*/(?=[^/]+^)","")"/>
</list>
<operator activated="true" class="print_to_console" compatibility="5.2.008" expanded="true" height="76" name="Print to Console" width="90" x="313" y="75">
<parameter key="log_value" value="OUTPUT: %{path_ending}"/>
<connect from_op="Set Macro" from_port="through 1" to_op="Generate Macro" to_port="through 1"/>
<connect from_op="Generate Macro" from_port="through 1" to_op="Print to Console" to_port="through 1"/>
</process>
</process>
Am I missing something obvious or might this be a bug?
