Hey,
i am new to data mining and RapidMiner especially. At the moment i work on my bachelor thesis where at some point i have to compare the fp-growth and the apriori algorithm.
The fp-growth algorithm within rapidminer works fine. But when i want to use apriori via weka-extension there is a problem. The help window says there is a paramenter Z (Z: Treat zero (i.e. first value of nominal attributes) as missing Range: boolean; default: false) . But within the process there is no such parameter. Is there a way to set the parameter anyway? Now my Results of apriori are wrong and i think this parameter set to true could fix this.
My dataset looks like that:
http://s7.directupload.net/file/d/2998/6noxngwr_png.htmThis is how the xml output looks like:
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="643" width="1028">
<operator activated="true" class="retrieve" compatibility="5.2.008" expanded="true" height="60" name="Retrieve" width="90" x="210" y="190">
<parameter key="repository_entry" value="Transformierte Transatkionsdatenbank"/>
<operator activated="true" class="select_attributes" compatibility="5.2.008" expanded="true" height="76" name="Select Attributes" width="90" x="313" y="435">
<parameter key="attribute" value="Hol_Link_1"/>
<operator activated="true" class="weka:W-Apriori" compatibility="5.1.001" expanded="true" height="60" name="W-Apriori" width="90" x="648" y="255">
<parameter key="M" value="0.5"/>
<parameter key="I" value="true"/>
<parameter key="V" value="true"/>
<connect from_op="Retrieve" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="W-Apriori" to_port="example set"/>
<connect from_op="W-Apriori" from_port="associator" to_port="result 1"/>
</process>
</process>
[ /code]
