<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.009"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.009" expanded="true" name="Process"> <process expanded="true" height="290" width="701"> <operator activated="true" class="text:create_document" compatibility="5.2.005" expanded="true" height="60" name="Create Document" width="90" x="45" y="30"> <parameter key="text" value="Rapid-I rockz"/> </operator> <operator activated="true" class="text:create_document" compatibility="5.2.005" expanded="true" height="60" name="Create Document (2)" width="90" x="45" y="120"> <parameter key="text" value="Rapid-I rulez"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.2.005" expanded="true" height="112" name="Process Documents" width="90" x="313" y="30"> <parameter key="vector_creation" value="Term Frequency"/> <process expanded="true" height="308" width="615"> <operator activated="true" class="text:tokenize" compatibility="5.2.005" expanded="true" height="60" name="Tokenize" width="90" x="112" y="30"> <parameter key="mode" value="specify characters"/> <parameter key="characters" value=".: "/> </operator> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="write_excel" compatibility="5.2.009" expanded="true" height="76" name="Write Excel" width="90" x="581" y="30"> <parameter key="excel_file" value="c:\tmp\test1.xls"/> </operator> <operator activated="true" class="text:wordlist_to_data" compatibility="5.2.005" expanded="true" height="76" name="WordList to Data" width="90" x="447" y="120"/> <operator activated="true" class="write_excel" compatibility="5.2.009" expanded="true" height="76" name="Write Excel (2)" width="90" x="581" y="120"> <parameter key="excel_file" value="c:\tmp\test2.xls"/> </operator> <connect from_op="Create Document" from_port="output" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Create Document (2)" from_port="output" to_op="Process Documents" to_port="documents 2"/> <connect from_op="Process Documents" from_port="example set" to_op="Write Excel" to_port="input"/> <connect from_op="Process Documents" from_port="word list" to_op="WordList to Data" to_port="word list"/> <connect from_op="Write Excel" from_port="through" to_port="result 1"/> <connect from_op="WordList to Data" from_port="example set" to_op="Write Excel (2)" to_port="input"/> <connect from_op="Write Excel (2)" from_port="through" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
