<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="460" width="685"> <operator activated="true" class="subprocess" compatibility="5.2.008" expanded="true" height="76" name="generate testdata" width="90" x="45" y="30"> <process expanded="true" height="505" width="705"> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="30"> <list key="attribute_values"> <parameter key="old_attribute" value=""obrero""/> <parameter key="frec" value="55"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="45" y="300"> <list key="attribute_values"> <parameter key="old_attribute" value=""estudiante""/> <parameter key="frec" value="2"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification (3)" width="90" x="45" y="390"> <list key="attribute_values"> <parameter key="old_attribute" value=""jubilado""/> <parameter key="frec" value="1"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification (4)" width="90" x="45" y="120"> <list key="attribute_values"> <parameter key="old_attribute" value=""patron""/> <parameter key="frec" value="30"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification (5)" width="90" x="45" y="210"> <list key="attribute_values"> <parameter key="old_attribute" value=""ama de casa""/> <parameter key="frec" value="3"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="5.2.008" expanded="true" height="148" name="Append" width="90" x="246" y="30"/> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 4"/> <connect from_op="Generate Data by User Specification (3)" from_port="output" to_op="Append" to_port="example set 5"/> <connect from_op="Generate Data by User Specification (4)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Generate Data by User Specification (5)" from_port="output" to_op="Append" to_port="example set 3"/> <connect from_op="Append" from_port="merged set" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="subprocess" compatibility="5.2.008" expanded="true" height="76" name="calculate average" width="90" x="179" y="30"> <process expanded="true" height="505" width="753"> <operator activated="true" class="aggregate" compatibility="5.2.008" expanded="true" height="76" name="Aggregate" width="90" x="112" y="75"> <list key="aggregation_attributes"> <parameter key="frec" value="average"/> </list> </operator> <operator activated="true" class="extract_macro" compatibility="5.2.008" expanded="true" height="60" name="Extract Macro" width="90" x="246" y="30"> <parameter key="macro" value="average"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="average(frec)"/> <parameter key="example_index" value="1"/> </operator> <connect from_port="in 1" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Aggregate" from_port="original" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="generate_attributes" compatibility="5.2.008" expanded="true" height="76" name="Generate new attribute" width="90" x="313" y="30"> <list key="function_descriptions"> <parameter key="new_attribute" value="if(frec<%{average},"otro",old_attribute)"/> </list> </operator> <connect from_op="generate testdata" from_port="out 1" to_op="calculate average" to_port="in 1"/> <connect from_op="calculate average" from_port="out 1" to_op="Generate new attribute" to_port="example set input"/> <connect from_op="Generate new attribute" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
