I would like to filter rows of a table using a blacklist
The structure of the blacklist is one column containing the name and a list of numbers ie:
NAME
123
562
588
The structure of the table to be filtered is three columns.
The first column contains numbers, the second and third have various content, ie:
A-----B-----C
123 text text
123 text text
562 text text
455 text text
During the process, the rows starting with "123" and "562" will be removed since these numbers are in the blacklist.
After a successful process, the result should be:
A-----B-----C
455 text text
There are logically 2 loops involved: pick one blacklisted number, check if present in each row the table, take action if positive, then pick next blacklisted number.
The direct use of the operator "Filtering examples" did work without any problem when I tested using no loop for the blacklist (ie: parameter string: %{loop_attribute}=123).
When I implemented the loop for the blacklist (using loop_attribute2) (operator "Filtering examples" with parameter string %{loop_attribute}=%{loop_attribute2}), nothing worked.
I tried an alternative solution I read in another post, using the operator "Generate Attributes".
I already spent a few hours on it, tried many things but I get stuck.
The result table is empty.
If seems the value of the attribute "Name" (from the first loop) is somehow lost in the subprocesses. I get either an empty table or an unfiltered table (if i invert the filters). I missed something with the "Macro" operator... but what?
Maybe can a clear mind help me here?
Thank you in advance
Alex
Here is the code so far
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="753" width="300">
<operator activated="true" class="read_excel" compatibility="5.2.008" expanded="true" height="60" name="Read Excel (2)" width="90" x="45" y="30">
<parameter key="excel_file" value="E:\Rapidminer\Blacklisting\blacklist.xls"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="0" value="Name.true.integer.attribute"/>
</list>
<operator activated="true" class="loop_examples" compatibility="5.2.008" expanded="true" height="94" name="Loop Examples" width="90" x="180" y="30">
<parameter key="iteration_macro" value="example1"/>
<process expanded="true" height="753" width="435">
<operator activated="true" class="read_excel" compatibility="5.2.008" expanded="true" height="60" name="Read Excel (4)" width="90" x="45" y="30">
<parameter key="excel_file" value="E:\Rapidminer\Blacklisting\to_filter.xls"/>
</list>
<parameter key="0" value="A.true.integer.attribute"/>
<parameter key="1" value="B.true.polynominal.attribute"/>
<parameter key="2" value="C.true.polynominal.attribute"/>
</list>
<operator activated="true" class="loop_examples" compatibility="5.2.008" expanded="true" height="76" name="Loop Examples (2)" width="90" x="179" y="30">
<parameter key="iteration_macro" value="example2"/>
<operator activated="true" class="generate_attributes" compatibility="5.2.008" expanded="true" height="76" name="Generate Attributes (4)" width="90" x="45" y="30">
<parameter key="toRemove" value="if("%{example2}"=="%{example1}", true, false)"/>
</list>
<operator activated="true" class="filter_examples" compatibility="5.2.008" expanded="true" height="76" name="Filter Examples (5)" width="90" x="180" y="30">
<parameter key="condition_class" value="attribute_value_filter"/>
<parameter key="parameter_string" value="toRemove != true"/>
<operator activated="true" class="select_attributes" compatibility="5.2.008" expanded="true" height="76" name="Select Attributes (5)" width="90" x="315" y="30">
<parameter key="attribute" value="toRemove"/>
<connect from_port="example set" to_op="Generate Attributes (4)" to_port="example set input"/>
<connect from_op="Generate Attributes (4)" from_port="example set output" to_op="Filter Examples (5)" to_port="example set input"/>
<connect from_op="Filter Examples (5)" from_port="example set output" to_op="Select Attributes (5)" to_port="example set input"/>
<connect from_op="Select Attributes (5)" from_port="example set output" to_port="example set"/>
<portSpacing port="sink_example set" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
</process>
<operator activated="true" class="set_macro" compatibility="5.2.008" expanded="true" height="76" name="Set Macro (2)" width="90" x="45" y="120">
<parameter key="macro" value="example1"/>
<parameter key="value" value="%{example1}"/>
<connect from_port="example set" to_op="Set Macro (2)" to_port="through 1"/>
<connect from_op="Read Excel (4)" from_port="output" to_op="Loop Examples (2)" to_port="example set"/>
<connect from_op="Loop Examples (2)" from_port="example set" to_port="example set"/>
<connect from_op="Set Macro (2)" from_port="through 1" to_port="output 1"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<connect from_op="Read Excel (2)" from_port="output" to_op="Loop Examples" to_port="example set"/>
<connect from_op="Loop Examples" from_port="example set" to_port="result 1"/>
</process>
</process>
