<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="421" width="547"> <operator activated="true" class="generate_nominal_data" compatibility="5.2.003" expanded="true" height="60" name="Generate Nominal Data" width="90" x="92" y="101"/> <operator activated="true" class="declare_missing_value" compatibility="5.2.003" expanded="true" height="76" name="Declare Missing Value" width="90" x="246" y="75"> <parameter key="mode" value="nominal"/> <parameter key="nominal_value" value="value1"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.2.003" expanded="true" height="76" name="Filter Examples" width="90" x="419" y="94"> <parameter key="condition_class" value="no_missing_attributes"/> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Declare Missing Value" to_port="example set input"/> <connect from_op="Declare Missing Value" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
