Perform a click on the start menu entry or a double click on the desktop icon in order to start RapidMiner. Please note that RapidMiner automatically uses 80% of the free memory during startup. This should be ok for most applications. If you run into memory problems, you should check out one of the other possibilities to start RapidMiner.
Starting RapidMiner: Any Platform - Way 1Two ways exist to start RapidMiner on any supported platform. The main reason why one should start RapidMiner with one of these ways is to adapt the amount of memory which is allowed for usage. The default Java installation uses only a small amount of memory (64 or 128 Mb) even if your system provides more physical memory (this is different for the Windows installation, see above). Therefore we recommend to define the maximum amount of memory which can be used by Java and the location of Java itself via the environment variables MAX_JAVA_MEMORY and JAVA_HOME:
haddock wrote:It also says..
