Dear all,
Does anyone happen to know whether there is a good way to weight examples?
I would like to achieve that newer examples are weighted higher.
ID att1 att2 weight
a 12 45 1
b 10 27 2
c 33 17 3
I tried to loop over all examples and write the iteration macro into a new generated attribute but that didn't work.
<process version="5.2.003">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process">
<process expanded="true" height="458" width="640">
<operator activated="true" class="generate_data" compatibility="5.2.003" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/>
<operator activated="true" class="loop_examples" compatibility="5.2.003" expanded="true" height="76" name="Loop Examples" width="90" x="179" y="30">
<process expanded="true" height="476" width="640">
<operator activated="true" class="generate_attributes" compatibility="5.2.003" expanded="true" height="76" name="Generate Attributes" width="90" x="45" y="30">
<parameter key="weight" value="%{example}"/>
</list>
<connect from_port="example set" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_port="example set"/>
<portSpacing port="sink_example set" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
</process>
<operator activated="true" class="set_role" compatibility="5.2.003" expanded="true" height="76" name="Set Role" width="90" x="313" y="30">
<parameter key="name" value="weight"/>
<parameter key="target_role" value="weight"/>
<connect from_op="Generate Data" from_port="output" to_op="Loop Examples" to_port="example set"/>
<connect from_op="Loop Examples" from_port="example set" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_port="result 1"/>
</process>
</process>
Thank you for sharing your ideas...
Sachs
