<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="235" width="480"> <operator activated="true" class="retrieve" compatibility="5.2.008" expanded="true" height="60" name="Retrieve" width="90" x="86" y="71"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.2.008" expanded="true" height="60" name="Extract Macro" width="90" x="246" y="75"> <parameter key="macro" value="fileName"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="a1"/> <parameter key="example_index" value="1"/> </operator> <operator activated="true" class="write_csv" compatibility="5.2.008" expanded="true" height="76" name="Write CSV" width="90" x="380" y="75"> <parameter key="csv_file" value="C:\%{fileName}"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Write CSV" to_port="input"/> <connect from_op="Write CSV" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Nils wrote:Hi,you can try something like this: <?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="235" width="480"> <operator activated="true" class="retrieve" compatibility="5.2.008" expanded="true" height="60" name="Retrieve" width="90" x="86" y="71"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.2.008" expanded="true" height="60" name="Extract Macro" width="90" x="246" y="75"> <parameter key="macro" value="fileName"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="a1"/> <parameter key="example_index" value="1"/> </operator> <operator activated="true" class="write_csv" compatibility="5.2.008" expanded="true" height="76" name="Write CSV" width="90" x="380" y="75"> <parameter key="csv_file" value="C:\%{fileName}"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Write CSV" to_port="input"/> <connect from_op="Write CSV" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process> Best,Nils
