<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="222" width="820"> <operator activated="true" class="generate_data" compatibility="5.2.003" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75"/> <operator activated="true" class="generate_attributes" compatibility="5.2.003" expanded="true" height="76" name="Generate Attributes" width="90" x="246" y="75"> <list key="function_descriptions"> <parameter key="bongo" value="if(att1<0&&att2<0,10,if(att3>0&&att4>0,20,0))"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="400" width="669"> <operator activated="true" class="generate_nominal_data" compatibility="5.2.008" expanded="true" height="60" name="Generate Nominal Data" width="90" x="112" y="165"/> <operator activated="true" class="generate_attributes" compatibility="5.2.008" expanded="true" height="76" name="Generate Attributes" width="90" x="246" y="165"> <list key="function_descriptions"> <parameter key="bongo" value="if(att1==value1&&att2==value2,10)"/> </list> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="400" width="669"> <operator activated="true" breakpoints="after" class="generate_nominal_data" compatibility="5.2.003" expanded="true" height="60" name="Generate Nominal Data" width="90" x="112" y="165"/> <operator activated="true" breakpoints="after" class="generate_attributes" compatibility="5.2.003" expanded="true" height="76" name="Generate Attributes" width="90" x="246" y="165"> <list key="function_descriptions"> <parameter key="bongo" value="if(att1=="value1"&&att2=="value2",10,0)"/> </list> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
