<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="222" width="820"> <operator activated="true" class="generate_data" compatibility="5.2.003" expanded="true" height="60" name="Generate Data" width="90" x="61" y="72"/> <operator activated="true" class="extract_macro" compatibility="5.2.003" expanded="true" height="60" name="Extract Macro" width="90" x="246" y="75"> <parameter key="macro" value="exs"/> </operator> <operator activated="true" class="aggregate" compatibility="5.2.003" expanded="true" height="76" name="Aggregate" width="90" x="385" y="73"> <list key="aggregation_attributes"> <parameter key="att1" value="sum"/> </list> </operator> <operator activated="true" class="extract_macro" compatibility="5.2.003" expanded="true" height="60" name="Extract Macro (2)" width="90" x="514" y="30"> <parameter key="macro" value="sum"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="sum(att1)"/> <parameter key="example_index" value="1"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.2.003" expanded="true" height="76" name="Generate Attributes" width="90" x="648" y="120"> <list key="function_descriptions"> <parameter key="exs" value="%{exs}"/> <parameter key="sum" value="%{sum}"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Extract Macro (2)" to_port="example set"/> <connect from_op="Aggregate" from_port="original" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Extract Macro (2)" from_port="example set" to_port="result 1"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
