<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="509" width="942"> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="112" y="165"> <list key="attribute_values"> <parameter key="attr1" value=""a,b,c""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="split" compatibility="5.2.008" expanded="true" height="76" name="Split" width="90" x="313" y="165"/> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Split" to_port="example set input"/> <connect from_op="Split" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
