Hi everybody,
I have a problem using the execute program module, the command I am trying to execute is
ssh user@remotehost touch /home/user/test
The actors are: my laptop, server1, server2.
the hosts recognize themself without password but with pub/private keys.
when I launch it from rapidminer with my laptop (authenticated in the same way) everything goes fine, but when I try to run it from rapidanalytics (remotely) it gives me this error:
Jul 26, 2012 5:58:30 PM <unknown> <unknown>
INFO: Process context is: Macros: [_ra_user : admin, _ra_jobID : 44]; Input: []; Output: []
INFO: No filename given for result file, using stdout for logging results!
INFO: Process //_LOCAL/smn/test666 starts
SEVERE: Process failed: com.rapidminer.operator.UserError: Process 'ssh user@remotehost touch /home/user/test' exited with error code 255.
at com.rapidminer.tools.Tools.waitForProcess(Tools.java:616)
at com.rapidminer.operator.CommandLineOperator.doWork(CommandLineOperator.java:94)
at com.rapidminer.operator.Operator.execute(Operator.java:834)
at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:51)
at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:711)
at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:379)
at com.rapidminer.Process.run(Process.java:925)
at com.rapidminer.Process.run(Process.java:848)
at com.rapidminer.Process.run(Process.java:807)
at com.rapidminer.Process.run(Process.java:802)
at de.rapidanalytics.execution.AbstractProcessExecutor.runProcessNow(Unknown Source)
at de.rapidanalytics.execution.SimpleProcessExecutor.execute(Unknown Source)
at de.rapidanalytics.execution.ProcessExecutionDispatcher.dispatch(Unknown Source)
at de.rapidanalytics.ejb.ProcessJobEJBImpl.executeJob(Unknown Source)
at sun.reflect.GeneratedMethodAccessor971.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.jboss.aop.joinpoint.MethodInvocation.invokeTarget(MethodInvocation.java:122)
at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:111)
at org.jboss.ejb3.interceptors.container.ContainerMethodInvocationWrapper.invokeNext(ContainerMethodInvocationWrapper.java:72)
at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.invoke(InterceptorSequencer.java:76)
at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.aroundInvoke(InterceptorSequencer.java:62)
at sun.reflect.GeneratedMethodAccessor407.invoke(Unknown Source)
at org.jboss.aop.advice.PerJoinpointAdvice.invoke(PerJoinpointAdvice.java:174)
at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.fillMethod(InvocationContextInterceptor.java:74)
at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_fillMethod_1853982725.invoke(InvocationContextInterceptor_z_fillMethod_1853982725.java)
at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.setup(InvocationContextInterceptor.java:90)
at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_setup_1853982725.invoke(InvocationContextInterceptor_z_setup_1853982725.java)
at org.jboss.ejb3.async.impl.interceptor.AsynchronousServerInterceptor.invoke(AsynchronousServerInterceptor.java:128)
at org.jboss.ejb3.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:62)
at org.jboss.ejb3.entity.TransactionScopedEntityManagerInterceptor.invoke(TransactionScopedEntityManagerInterceptor.java:56)
at org.jboss.ejb3.AllowedOperationsInterceptor.invoke(AllowedOperationsInterceptor.java:47)
at org.jboss.ejb3.tx.StatelessBMTInterceptor.handleInvocation(StatelessBMTInterceptor.java:106)
at org.jboss.ejb3.tx.BMTInterceptor.invoke(BMTInterceptor.java:55)
at org.jboss.ejb3.stateless.StatelessInstanceInterceptor.invoke(StatelessInstanceInterceptor.java:68)
at org.jboss.ejb3.core.context.SessionInvocationContextAdapter.proceed(SessionInvocationContextAdapter.java:95)
at org.jboss.ejb3.tx2.impl.CMTTxInterceptor.invokeInOurTx(CMTTxInterceptor.java:247)
at org.jboss.ejb3.tx2.impl.CMTTxInterceptor.required(CMTTxInterceptor.java:349)
at org.jboss.ejb3.tx2.impl.CMTTxInterceptor.invoke(CMTTxInterceptor.java:209)
at org.jboss.ejb3.tx2.aop.CMTTxInterceptorWrapper.invoke(CMTTxInterceptorWrapper.java:52)
at org.jboss.aspects.tx.TxPropagationInterceptor.invoke(TxPropagationInterceptor.java:76)
at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.java:42)
at org.jboss.ejb3.security.Ejb3AuthenticationInterceptorv2.invoke(Ejb3AuthenticationInterceptorv2.java:182)
at org.jboss.ejb3.ENCPropagationInterceptor.invoke(ENCPropagationInterceptor.java:41)
at org.jboss.ejb3.BlockContainerShutdownInterceptor.invoke(BlockContainerShutdownInterceptor.java:67)
at org.jboss.ejb3.core.context.CurrentInvocationContextInterceptor.invoke(CurrentInvocationContextInterceptor.java:47)
at org.jboss.aspects.currentinvocation.CurrentInvocationInterceptor.invoke(CurrentInvocationInterceptor.java:67)
at org.jboss.ejb3.interceptor.EJB3TCCLInterceptor.invoke(EJB3TCCLInterceptor.java:86)
at org.jboss.ejb3.stateless.StatelessContainer.dynamicInvoke(StatelessContainer.java:392)
at org.jboss.ejb3.remoting.IsLocalInterceptor.invokeLocal(IsLocalInterceptor.java:88)
at org.jboss.ejb3.remoting.IsLocalInterceptor.invoke(IsLocalInterceptor.java:75)
at org.jboss.ejb3.async.impl.interceptor.AsynchronousClientInterceptor.invoke(AsynchronousClientInterceptor.java:143)
at org.jboss.aspects.remoting.PojiProxy.invoke(PojiProxy.java:62)
at $Proxy215.invoke(Unknown Source)
at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:185)
at $Proxy214.executeJob(Unknown Source)
at de.rapidanalytics.web.tools.ProcessExecutionJob.execute(Unknown Source)
at org.quartz.core.JobRunShell.run(JobRunShell.java:216)
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:549)
SEVERE: Here: Process[1] (Process)
subprocess 'Main Process'
==> +- Execute Program[1] (Execute Program)
Can someone help me out please?
Thanks,
U.
