Problems Running RapidAnalytics - JBoss errors
I have installed RapidAnalytics on Linux Redhat (65). Install seemed to go fine. (Installed MySQL, Java 1.7, created rapidanalytics db and user and other prerequisite steps. Also checked that JBOSS_HOME not set already.) But on the first run of RA, I get errors and can't start the application. The start of the server.log shows the following:
2012-07-18 16:06:37,267 INFO [org.apache.coyote.http11.Http11Protocol] (Thread-2) Starting Coyote HTTP/1.1 on http-8080
2012-07-18 16:06:37,269 INFO [org.apache.coyote.ajp.AjpProtocol] (Thread-2) Starting Coyote AJP/1.3 on ajp-127.0.0.1-8009
2012-07-18 16:06:37,270 INFO [org.jboss.bootstrap.impl.base.server.AbstractServer] (Thread-2) JBossAS [6.0.0.Final "Neo"] Started in 1m:8s:389ms
2012-07-18 16:22:30,846 ERROR [ProfileServiceBootstrap] (Thread-2) Failed to load profile:: org.jboss.deployers.client.spi.IncompleteDeploymentException: Summary of incomplete deployments (SEE PREVIOUS ERRORS FOR DETAILS):
DEPLOYMENTS MISSING DEPENDENCIES:
Deployment "CachedConnectionManager" is missing the following dependencies:
Dependency "TransactionManager" (should be in state "Installed", but is actually in state "Configured")
Deployment "ConnectorMBean" is missing the following dependencies:
Dependency "jboss.remoting:service=Connector,transport=socket" (should be in state "Create", but is actually in state "** NOT FOUND Depends on 'jboss.remoting:service=Connector,transport=socket' **")
Deployment "DefaultUserTransactionprovider" is missing the following dependencies:
Dependency "<UNKNOWN DefaultUserTransactionprovider>" (should be in state "Installed", but is actually in state "** UNRESOLVED Demands 'TransactionManager' **")
Deployment "DeploymentInvocationHandler" is missing the following dependencies:
Dependency "ConnectorMBean" (should be in state "Installed", but is actually in state "Configured")
Deployment "DeploymentManager" is missing the following dependencies:
Deployment "JBossTransactionServices" is missing the following dependencies:
Deployment "JMSConnectionFactoryManageMO" is missing the following dependencies:
Dependency "<UNKNOWN JMSConnectionFactoryManageMO>" (should be in state "Installed", but is actually in state "** UNRESOLVED Demands 'JMSServerManager' **")
Deployment "JMSQueueManageMO" is missing the following dependencies:
Dependency "<UNKNOWN JMSQueueManageMO>" (should be in state "Installed", but is actually in state "** UNRESOLVED Demands 'JMSServerManager' **")
Deployment "JMSServerMO" is missing the following dependencies:
Dependency "<UNKNOWN JMSServerMO>" (should be in state "Installed", but is actually in state "** UNRESOLVED Demands 'JMSServerManager' **")
Deployment "JMSTopicManageMO" is missing the following dependencies:
Dependency "<UNKNOWN JMSTopicManageMO>" (should be in state "Installed", but is actually in state "** UNRESOLVED Demands 'JMSServerManager' **")
Deployment "JndiBinder" is missing the following dependencies:
Dependency "jboss:service=Naming" (should be in state "Create", but is actually in state "** NOT FOUND Depends on 'jboss:service=Naming' **")
Deployment "MBeanManagedOperationProxyFactory" is missing the following dependencies:
[root@IBI_RapidMiner log]#
