Hi .. i know we can get a Graph for weighting but my problem is i have so many attributes and i just need attributes which weights are more than .5
so for doing this i used select by weight then used data to weight operators ....but THE big problem is when i use it ....data to weight,weights all remaining attributes 1 ! which is not correct ..what should i do?
Second question: which operators are good or can be used for visualization...i already know that decision trees provide an excellent visual model....my job needs good graphs and model which are not so hard to explain yet they are attractive too
Danke schon
and here is xml code for my first Q
<process version="5.2.006">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process">
<process expanded="true" height="541" width="1017">
<operator activated="true" class="retrieve" compatibility="5.2.006" expanded="true" height="60" name="Retrieve" width="90" x="112" y="300">
<parameter key="repository_entry" value="//HUSSAINI/Data/F C Data"/>
<operator activated="true" class="select_attributes" compatibility="5.2.006" expanded="true" height="76" name="Select Attributes" width="90" x="246" y="300">
<parameter key="attribute_filter_type" value="value_type"/>
<parameter key="value_type" value="numeric"/>
<operator activated="true" class="multiply" compatibility="5.2.006" expanded="true" height="94" name="Multiply" width="90" x="380" y="255"/>
<operator activated="true" class="featselext:maximum_relevance_weighting" compatibility="1.1.004" expanded="true" height="76" name="MR-Weighting" width="90" x="514" y="390"/>
<operator activated="true" class="featselext:sam_weighting" compatibility="1.1.004" expanded="true" height="76" name="Weight by SAM" width="90" x="514" y="210"/>
<operator activated="true" class="select_by_weights" compatibility="5.2.006" expanded="true" height="94" name="Select by Weights" width="90" x="648" y="210">
<parameter key="weight" value="0.5"/>
<operator activated="true" class="data_to_weights" compatibility="5.2.006" expanded="true" height="76" name="Data to Weights" width="90" x="782" y="210"/>
<operator activated="true" class="select_by_weights" compatibility="5.2.006" expanded="true" height="94" name="Select by Weights (2)" width="90" x="648" y="390">
<operator activated="true" class="data_to_weights" compatibility="5.2.006" expanded="true" height="76" name="Data to Weights (2)" width="90" x="783" y="300"/>
<connect from_op="Retrieve" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Weight by SAM" to_port="example set"/>
<connect from_op="Multiply" from_port="output 2" to_op="MR-Weighting" to_port="example set"/>
<connect from_op="MR-Weighting" from_port="weights" to_op="Select by Weights (2)" to_port="weights"/>
<connect from_op="MR-Weighting" from_port="example set" to_op="Select by Weights (2)" to_port="example set input"/>
<connect from_op="Weight by SAM" from_port="weights" to_op="Select by Weights" to_port="weights"/>
<connect from_op="Weight by SAM" from_port="example set" to_op="Select by Weights" to_port="example set input"/>
<connect from_op="Select by Weights" from_port="example set output" to_op="Data to Weights" to_port="example set"/>
<connect from_op="Data to Weights" from_port="weights" to_port="result 1"/>
<connect from_op="Select by Weights (2)" from_port="example set output" to_op="Data to Weights (2)" to_port="example set"/>
<connect from_op="Data to Weights (2)" from_port="weights" to_port="result 2"/>
</process>
</process>
